USDRT 7.5.1
I am trying to port my connector from Vanilla USD to USDRT. Hence I am creating the prims directly in fabric and applying transforms to it using using RtXformable API.
I am trying to create the following
*Mesh
*Cube
  • Cone
  • Sphere
    then update its attribute as well as applying transforms to it as Described in the link .
As described in the post, I created following attributes
  • CreateWorldExtentAttr
  • CreateFabricHierarchyWorldMatrixAttr
  • CreateFabricHierarchyLocalMatrixAttr
  • _worldVisibility
  • purpose
But it is not working as expected. Can anyone give me some pointers which I am missing to set while working with USDRT.
Ok let me ask the dev team that works on USDRT and get back to you.
Thanks @Richard3D. Looking forward for your reply. Kind of stuck with my implementation.
We have example extensions at kit-extension-template-cpp/source/extensions at main · NVIDIA-Omniverse/kit-extension-template-cpp · GitHub
omni.example.usdrt_meshomni.example.cpp.usdrtomni.example.python.usdrt
This this line specifically:
def create_mesh_usdrt(stage: usdrt.Usd.Stage, prim_path: str, num_x_divisions: int, num_z_divisions: int):
Thanks @Richard3D for the reply. I have the following code for generating cube and then rescaling it. After execution the cube gets generated in the viewport but it does not rescale.
import omni.usd
from usdrt import Usd, Sdf, Gf, UsdGeom,Rt
usd_context = omni.usd.get_context()
stage = Usd.Stage.Attach(usd_context.get_stage_id())
prim = stage.DefinePrim(“/Ground/Cube”, “Cube”)
rtbound = Rt.Boundable(prim)
world_ext = rtbound.CreateWorldExtentAttr()
world_ext.Set(Gf.Range3d(Gf.Vec3d(-0.5, -0.5, -0.5), Gf.Vec3d(0.5, 0.5, 0.5)))
xformable = Rt.Xformable(prim)
attr = xformable.GetFabricHierarchyLocalMatrixAttr()
if not attr:
xformable.CreateFabricHierarchyLocalMatrixAttr()
current_xform = attr.Get()
current_xform.SetScale((20, 10, 5))
attr.Set(current_xform)
Hey @rashik.thalappully
The issue with your code above is a misuse of SetScale()
Try with this code:
import omni.usd
from usdrt import Usd, Sdf, Gf, UsdGeom, Rt
# Get USD stage
# Define a cube
prim = stage.DefinePrim("/Ground/Cube", "Cube")
# Set the extent
# Apply scale using FabricHierarchyLocalMatrix
# Create a scale matrix
scale_vec = Gf.Vec3d(20.0, 10.0, 5.0)
scale_matrix = Gf.Matrix4d(1.0)  # Identity
scale_matrix.SetScale(scale_vec)
# Set it on the attribute
xform_attr = xformable.CreateFabricHierarchyLocalMatrixAttr(scale_matrix)
Hi @AshleyG_NVIDIA
Thanks for the reply. I have updated the code as follows
import omni.usd
prim = stage.DefinePrim("/World/Cube", "Cube")
if not attr:
    print("CreateFabricHierarchyLocalMatrixAttr")
current_xform.SetScale(Gf.Vec3d(20.0, 100.0, 5.0))
print(current_xform)
print(attr.Get())
but still does not scale. Please refer the following screenshot to see the output. But the attribute value is updated with the new value.
Unfortunately the World Space Matrix update code only considers prims that are fully “connected” in the Fabric Hierarchy, and the USDRT API has a bug in kit 106 where it does not “autoconnect” prims defined in USDRT. This bug is already fixed for Kit 107.
The workaround for now is to directly author the World Space Matrix instead:
Blockquote
import omni.usd
prim = stage.DefinePrim(“/World/Cube”, “Cube”)
if not attr:
print(“CreateFabricHierarchyLocalMatrixAttr”)
xformable.CreateFabricHierarchyWorldMatrixAttr()
attr = xformable.GetFabricHierarchyWorldMatrixAttr()
print(attr.Get())
Hi @abaillet
During my experimentation yesterday, I have the following code snippet where scaling was working.
import omni.usd
localAttr = xformable.GetFabricHierarchyLocalMatrixAttr()
if not localAttr:
worldAttr = xformable.GetFabricHierarchyWorldMatrixAttr()
if not worldAttr:
    print("CreateFabricHierarchyWorldMatrixAttr")
current_xform = localAttr.Get()
localAttr.Set(current_xform)
print(localAttr.Get())
The only difference is
  • Created ‘CreateFabricHierarchyWorldMatrixAttr’ and updated the Local Matrix only, then the scaling was working as shown the picture below.
I noticed that the shape appears in the viewport even without setting the extend attributes when the Fabric delegate is enabled. Are these attributes not mandatory for display?
Additionally, I installed Kit 107, but the usdrt.scenegraph version is still 7.5.1, the same as in Kit 106.5.0. Has the fix already been included in version 7.5.1?
Thanks for your clarification!
Specifically, what is your current error and issue with it now? You said you got scaling working ok.
Closing for lack of further information
