I am trying to move some code that’s:
- Running as part of a standalone application using the isaacsim SimulationApp
- Doing some procedural generation that spawns a bunch of prims using the Python USD APIs
- Is pretty slow right now because of the high amount of USD changes this is doing
over to USDRT for performance improvements.
According to the USDRT documentation here: USDRT Python API Reference — usdrt 7.5.1 documentation the USDRT API should be pin-compatible with USD, but right now while some parts are working, most of the physics-related APIs seem to be broken, for example, trying to use UsdPhysics.CollisionAPI.Apply gives:
AttributeError: type object 'usdrt.UsdPhysics._UsdPhysics.CollisionAPI' has no attribute 'Apply'
and UsdShade.MaterialBindingAPI appears to not have a Bind method either (though this does match the documentation)
Is there another way to interact with the stuff from UsdPhysics/PhysxSchema/UsdShade via USDRT I’m missing? Or some other way to make mass creation of geometry primitives and joints faster.
