Use sdkmanager to flash the jetson orin nx failed
I am trying to flash my Nvidia Jetson Orin NX 16GB with JetPack 6.0, but it fails.
Every time I click the Flash button in the under above picture ,it will failed.
the log in the terminal is under above:
19:49:27 INFO: Device info before flash: Jetson Orin NX 16GB | 001/019 | 1-1 | 2.002.00 | Recovery | 0955:7323
19:49:27 DEBUG: running command < true >
19:49:27 INFO: command finished successfully
19:49:27 DEBUG: running command < /tmp/device_mode_host_setup.luodeng.sh >
19:49:27 INFO: exec_command: /tmp/device_mode_host_setup.luodeng.sh
19:49:27 INFO: [host] [sudo] password for luodeng:
19:49:27 INFO: net.ipv4.ip_forward = 1
19:49:27 INFO: Device mode on host successfully set with DNS 8.8.8.8!
19:49:28 DEBUG: running command < true >
19:49:28 INFO: command finished successfully
19:49:28 DEBUG: Flash Jetson Linux - flash: using adapter to install NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS to /home/luodeng/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS
19:49:28 INFO: Flash Jetson Linux - flash: current working directory is /home/luodeng/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra
19:49:28 INFO: Flash Jetson Linux - flash: user entered nvme0n1p1
19:49:28 INFO: Flash Jetson Linux - flash: *** Checking ONLINE mode … OK.
19:49:28 INFO: Flash Jetson Linux - flash: *** Checking target board connection … 1 connections found.
19:49:28 INFO: Flash Jetson Linux - flash: *** Reading ECID … FUSELEVEL=fuselevel_production hwchipid=0x23 bootauth=NS
19:49:28 INFO: Flash Jetson Linux - flash: *** Reading EEPROM … “/home/luodeng/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py” --chip 0x23 --applet “/home/luodeng/nvidia/nvidia_sdk/JetPack_5.1.4_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins “mb2_applet applet_t234.bin” --skipuid --cmd “dump eeprom cvm cvm.bin; reboot recovery”
19:49:28 INFO: Flash Jetson Linux - flash: ModuleNotFoundError: No module named ‘yaml’
19:49:28 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 0s ]
19:49:28 ERROR: Flash Jetson Linux - flash: command terminated with error
19:49:28 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
Run "pip install pyyaml " and try again.
Thanks for your reply.
1729644358255
My host machine has installed the pyyaml before. I tried again after run "pip install pyyaml ", the results has never changed.
Looking forward your further reply.
What is the default python running on your host? Python3 or python2?
My default python is python2. I changed the default python to python3, it still dose not work.
There is a “EXPORT LOGS” button on sdkmanager. Please click it after your flash failure and attach the whole zip file here.
The “export logs” file is under above.
SDKM_logs_JetPack_5.1.4_Linux_for_Jetson_Orin_NX_modules_2024-10-24_14-57-08.zip (65.3 KB)
Could you also try pip3 install pyyaml?
The log is still same.
As your suggestion , I runned “pip3 install pyyaml”, the result is under above.
please fix that by yourself. This is not related to what we can help here.
I have fixed the problem of “pip3 install pyyaml” .
But it does not still work!
In my opinion , the device has recognized the usb.
Why it still need I unplug the USB and PowerJack . I Ifollowed the requirements, but it still couldn’t be Flashed.
Could you just test if any of your python2 or python3 can import yaml?
Thanks for your reply .
I have made a test with ChatGPT suggestion. The result is under above.
Looks like your python2 still has no yaml installed.
I have installed the yaml of python2 and python3, but it still does not work!
1730096065001
I think the problem is probably not the yaml.
The log is under above.
14:11:55 SUMMARY: File System and OS - target_image: Install completed successfully.
14:12:10 INFO: Device info before flash: Jetson Orin NX 16GB | 001/002 | 1-1 | 2.002.00 | Recovery | 0955:7323
14:12:10 DEBUG: running command < true >
14:12:10 INFO: exec_command: /tmp/device_mode_host_setup.luodeng.sh
14:12:10 INFO: Found route default ens33, setting up device mode
14:12:10 INFO: net.ipv4.ip_forward = 1
14:12:10 INFO: Device mode on host successfully set with DNS 8.8.8.8!
14:12:10 INFO: command finished successfully
14:12:11 DEBUG: running command < true >
14:12:11 INFO: exec_command: true
14:12:11 INFO: command finished successfully
14:12:11 DEBUG: running command < bash /tmp/PREFLASH_VERIFY_JP_61.sh >
14:12:21 INFO: sudo ./nvautoflash.sh --print_boardid to verify access to jetson bootrom
14:12:21 INFO: *** Checking ONLINE mode … OK.
14:12:21 INFO: *** Checking target board connection … 1 connections found.
14:12:21 INFO: *** Reading ECID … FUSELEVEL=fuselevel_production hwchipid=0x23 bootauth=NS
14:12:21 INFO: *** Reading EEPROM … “/home/luodeng/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py” --chip 0x23 --applet “/home/luodeng/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins “mb2_applet applet_t234.bin” --skipuid --cmd “dump eeprom cvm cvm.bin; reboot recovery”
14:12:22 INFO: ModuleNotFoundError: No module named ‘yaml’
14:12:22 ERROR: — Error: Reading board information failed.
14:12:22 INFO: command finished successfully
14:12:24 DEBUG: running command < true >
14:12:24 INFO: exec_command: true
14:12:24 INFO: command finished successfully
14:12:24 DEBUG: Flash Jetson Linux - flash: using adapter to install NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS to /home/luodeng/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NX_TARGETS
14:12:24 INFO: Flash Jetson Linux - flash: current working directory is /home/luodeng/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra
14:12:24 INFO: Flash Jetson Linux - flash: sudo ./nvsdkmanager_flash.sh --storage nvme0n1p1 --nv-auto-config --username agent09
14:12:24 INFO: Flash Jetson Linux - flash: user entered nvme0n1p1 --nv-auto-config --username agent09
14:12:24 INFO: Flash Jetson Linux - flash: *** Checking ONLINE mode … OK.
14:12:24 INFO: Flash Jetson Linux - flash: *** Checking target board connection … 1 connections found.
14:12:24 INFO: Flash Jetson Linux - flash: *** Reading ECID … FUSELEVEL=fuselevel_production hwchipid=0x23 bootauth=NS
14:12:24 INFO: Flash Jetson Linux - flash: *** Reading EEPROM … “/home/luodeng/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py” --chip 0x23 --applet “/home/luodeng/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins “mb2_applet applet_t234.bin” --skipuid --cmd “dump eeprom cvm cvm.bin; reboot recovery”
14:12:24 INFO: Flash Jetson Linux - flash: ModuleNotFoundError: No module named ‘yaml’
14:12:24 ERROR: Flash Jetson Linux - flash: *** ERROR: Parsing boardid failed
14:12:24 ERROR: Flash Jetson Linux - flash: command terminated with error
14:12:24 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
Could you go to your “/home/luodeng/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/”
and run this command directly and see what would happen?
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-orin-nano-devkit internal
I have run the command and the result was under above.
Will entering this command in python console work?
 python
Python 2.7.18 (default, Jul  1 2022, 12:27:04)
[GCC 9.4.0] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import yaml
python3
Python 3.8.10 (default, Sep 11 2024, 16:02:53)
>>> import yaml
And what is the result of ls -l /usr/bin/python?
The results is under above.
1730103487343
