Use sdkmanager to flash the jetson orin nx failed
I have changed the PYTHONPATH with chatgpt’s opinion, and try Flash gain ,but it still doesn’t work.
What is this result?
19:16:31.611 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [ Component Install Finished with Error ]
19:16:31.611 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: [host] [ Disk Avail on Partition : 0.00 B ]
Do you have enough disk space on your host?
Are you using standalone Ubuntu host PC or VM/docker?
I am use VM。
How much disk space I need on my host?
The result is under above.
1730107246451
I seem to have the exact same problem as @deng.luo. The Python versions seem to be as they were suggested by @WayneWWW:
python -V
Python 2.7.18
python2 -V
Python 2.7.18
python3 -V
Python 3.8.16
import yaml does also work in both Python Versions.
The problem is, that the tegrasign_v3_util.py script seems to be run in a Python3 environment (no matter the shebang, as suggested here) as
#!/usr/local/bin/python2
# Copyright (c) 2018-2024, NVIDIA Corporation.  All Rights Reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
from __future__ import print_function
import binascii
import hashlib
import json
import math
import struct
import os, sys
import subprocess
import re
import time
import traceback
print(sys.version)
import yaml
returns:
3.8.16 (default, Sep 10 2024, 13:23:32)
[GCC 11.4.0]
EDIT:
JetPack6.0 and JetPack6.1 both produce this error.
EDIT2:
For me using sudo -i and installing pyYAML with the root user (pip install pyyaml) seems to have solved my problem.
Thanks for your reply.
I have changed to root and installed the pyyaml in root user. It has seemed to solved my problem too.
Thanks you so much.
