I want to use the Jetson nano as a field device that collects sensor and audio data, visualizes the results using the GPU and then acts as a server with a wifi Access Point that displays the results as well as provides access to the recorded data via ftp. I am at the stage now where i have prototyped everything and wanted to start work on the access point and server, the problem i’m having is to do with configuring an access point using a ‘Tp-Link TL-WN725N’ wireless N Nano USB Adapter.
I followed an old post where somebody already had some success in doing this: https://forums.developer.nvidia.com/t/creating-wifi-ap-hotspot-on-jetson-nano/72982
I got to the final command from the solution using nmcli (network manager) nmcli con up JetsonAP but was greeted with an error, Error: Connection activation failed: No suitable device found for this connection.
As that thread was closed in 2019, I am asking here for advice on what you think i should try next, or if there is a better hardware that i should be using instead of this TP-Link? The device works fine for connecting to other wifi routers but does not configure as an AP , i also saw it does not have drivers for aarch64, so i guess that is sub optimal but strange it works in other configurations.
Thank you if you could help.
