I’ve been able to get the Nano running with the IMX219 Leopard camera kit (https://leopardimaging.com/product/li-imx219-mipi-af-nano/). I am now interested in using the Nano with a different sensor. I would like to use the Nano with two Sony IMX335 cameras (https://leopardimaging.com/product/li-jetson-kit-imx335-x/).
My questions are:
What is involved with getting the IMX335 running instead of the IMX219 with the Nano? I know I will need to take care of the cabling which is no problem. From a software standpoint, will this work out of the box using Jetpack or are some modifications necessary? Is there a guide or an example you can point me to?
What is the gstreamer pipeline path to access two cameras? I use the following command to get video from a single IMX219:
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=616’ ! nvvidconv ! nvegltransform ! nveglglessink -e
What would the similar command be to access the second camera?
Thanks in advance.
