I am working on setting up a couple hundred devices for production. My goal is to be able to reboot the boards to either recovery or standard modes over the usb0 connection.
I am able to flash them without issue and I notice there is a line at the end of the flashing script to use tegradevflash --reboot coldboot to boot the device into the standard mode.
I was hoping to use this tool to set the boot mode for the device, but when I have a device in recovery mode and send the command the screen hangs and eventually the host machine kills the process for being unresponsive:
sudo ./tegradevflash --instance /001/028 --reboot coldboot
Is there anything I am missing to run this command? Are the environment variables that I need to setup for this to work?
