Xavier agx stopped working randomly. Attempting to repair with sdk. Unfortunately it needs to install visionworks on my host computer before it can fix my xavier for some reason. Everything else installed fine on my host pc, but visionworks does not work.
trying to run the commands manually gives:
Unable to locate package libvisionworks
@ivan_viti
Could you share the error log? also what error reported that block the xavier working.
Visionworks is the libs which is optional will not block the xavier in normal case.
