Hello
I have question about JETSON AGX XAVIER. I encountered an error while installing the jetpack 4.5 package via sdkmanager. Error message is
01:32:11 ERROR: VisionWorks on Host: E: Unable to correct problems, you have held broken packages.
01:32:11 INFO: VisionWorks on Host: [ Package Install Finished with Error ]
01:32:11 INFO: VisionWorks on Host: [host] [ 33.29 MB used. Disk Avail: 764.46 GB ]
01:32:11 INFO: VisionWorks on Host: [ NV_VISIONWORKS_HOST_COMP Install took 12s ]
01:32:11 ERROR: VisionWorks on Host: [error]: Error when apt install failed; [exec_command]: sudo apt-get update; sleep 0.5; sudo apt-get -y install libvisionworks=1.6.0.501* libvisionworks-dev=1.6.0.501* libvisionworks-samples=1.6.0.501* ; [error]: exit status 100; [deb_path]: /home/jetson/jet1/libvisionworks-repo_1.6.0.501_amd64.deb
01:32:11 ERROR: VisionWorks on Host: command terminated with error
01:32:11 SUMMARY: VisionWorks on Host: First Error: APT system is broken and requires manual fix
How can ı solve this error ?
