I cannot successfully run the Visionworks sample that are included with Jetpack 4.2.1. I am compiling them on the Jetson Nano after a fresh install/sd card flash of the “jetson-nano-sd-r32.2-2019-07-16” image.
When I try and run the compiled samples, the all error out with the error:
Error: Can't open source URI /home/ale/Documents/visionworks/VisionWorks-1.6-Samples/bin/../data/cars.mp4
I get the same error even if I try and hard code the path to the assets in the source file.
Maybe the FrameSource object is failing at loading the sample media files.
Is there a fix that I’ve missed to get these sample up and running?
