My development machine is 64-bit Vista, but the OpenCL 1.0 conformant release says only the WinXP drivers will work. I’ve seen posts that the 190 drivers only support CUDA 2.3 and NOT OpenCL. Why not? Stability, I’m guessing. I’ve also seen posts of people using Vista and working with OpenCL, so I’m pretty sure its possible.
Do the 185 Vista-64 drivers support OpenCL? If so, this point is needs to be stated clearly. If not, what do I have to do? I can’t use XP because HP doesn’t support XP for my dual Xeon workstation.
