I have developed a good working CUDA imaging Nsight solution in Visual Studio 2022 and wanted to move some ad-hoc tests to a proper Google Test platform in a new project as part of that solution. My problem is it’s pretty easy to add a Google Test Project to a solution but adding my test code wont build against the Cuda Toolkit (or support GPU debugging).
Alternatively, adding a Google Test Nuget plugin to a CUDA project will compile and link my existing code dependent on the cuda platform, the linker fails on the Google Test content.
Has anyone built a Google Test project in VS NSight that links and runs? Any pointers to how to set that up?
I’m running the Cuda 12.3 toolkit.
Steve
