I have installed VLC on my Nvidia Jetson nano via command line. Everything ok, but now opening whatever file (doesn’t really matter) VLC crashes, have a look to the logs:
-- logger module started --
main debug: VLC media player - 3.0.4 Vetinari
main debug: Copyright © 1996-2018 the VideoLAN team
main debug: revision 3.0.4-0-gf615db6332
main debug: configured with ./configure '--build=aarch64-linux-gnu' '--prefix=/usr' '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--sysconfdir=/etc' '--localstatedir=/var' '--disable-silent-rules' '--libdir=${prefix}/lib/aarch64-linux-gnu' '--libexecdir=${prefix}/lib/aarch64-linux-gnu' '--runstatedir=/run' '--disable-maintainer-mode' '--disable-dependency-tracking' '--config-cache' '--disable-update-check' '--enable-fast-install' '--docdir=/usr/share/doc/vlc' '--with-binary-version=3.0.4-1ubuntu0.2' '--enable-a52' '--enable-aa' '--enable-aribsub' '--enable-bluray' '--enable-avahi' '--enable-caca' '--enable-chromaprint' '--enable-chromecast' '--enable-dbus' '--enable-dca' '--enable-dvbpsi' '--enable-dvdnav' '--enable-faad' '--enable-flac' '--enable-fluidsynth' '--enable-freetype' '--enable-fribidi' '--enable-gles2' '--enable-gnutls' '--enable-harfbuzz' '--enable-jack' '--enable-kate' '--enable-libass' '--enable-libmpeg2' '--enable-libxml2' '--enable-lirc' '--enable-live555' '--enable-mad' '--enable-matroska' '--enable-mod' '--enable-mpc' '--enable-mpg123' '--enable-mtp' '--enable-ncurses' '--enable-notify' '--enable-ogg' '--enable-opus' '--enable-pulse' '--enable-qt' '--enable-realrtsp' '--enable-samplerate' '--enable-sdl-image' '--enable-sftp' '--enable-shine' '--enable-shout' '--enable-skins2' '--enable-sndio' '--enable-soxr' '--enable-speex' '--enable-svg' '--enable-svgdec' '--enable-taglib' '--enable-theora' '--enable-twolame' '--enable-upnp' '--enable-vdpau' '--enable-vnc' '--enable-vorbis' '--enable-x264' '--enable-x265' '--enable-zvbi' '--with-kde-solid=/usr/share/solid/actions/' '--disable-d3d11va' '--disable-decklink' '--disable-directx' '--disable-dsm' '--disable-dxva2' '--disable-fdkaac' '--disable-fluidlite' '--disable-freerdp' '--disable-goom' '--disable-gst-decode' '--disable-libtar' '--disable-macosx' '--disable-macosx-avfoundation' '--disable-macosx-qtkit' '--disable-mfx' '--disable-opencv' '--disable-projectm' '--disable-schroedinger' '--disable-sparkle' '--disable-srt' '--disable-telx' '--disable-vpx' '--disable-vsxu' '--disable-wasapi' '--enable-alsa' '--enable-dc1394' '--enable-dv1394' '--enable-libplacebo' '--enable-linsys' '--enable-nfs' '--enable-omxil' '--enable-udev' '--enable-v4l2' '--enable-wayland' '--enable-libva' '--enable-vcd' '--enable-smbclient' '--disable-oss' '--disable-crystalhd' '--disable-mmx' '--disable-sse' '--disable-neon' '--disable-altivec' 'build_alias=aarch64-linux-gnu' 'CFLAGS=-g -O2 -fdebug-prefix-map=/build/vlc-p_h2t7/vlc-3.0.4=. -fstack-protector-strong -Wformat -Werror=format-security ' 'LDFLAGS=-Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,now -Wl,--as-needed' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2' 'CXXFLAGS=-g -O2 -fdebug-prefix-map=/build/vlc-p_h2t7/vlc-3.0.4=. -fstack-protector-strong -Wformat -Werror=format-security ' 'OBJCFLAGS=-g -O2 -fdebug-prefix-map=/build/vlc-p_h2t7/vlc-3.0.4=. -fstack-protector-strong -Wformat -Werror=format-security'
main debug: searching plug-in modules
main debug: loading plugins cache file /usr/lib/aarch64-linux-gnu/vlc/plugins/plugins.dat
main debug: recursively browsing `/usr/lib/aarch64-linux-gnu/vlc/plugins'
main debug: plug-ins loaded: 511 modules
main debug: opening config file (/home/company/.config/vlc/vlcrc)
main debug: looking for logger module matching "any": 4 candidates
file debug: opening logfile `/home/company/Desktop/testino.log'
main debug: using logger module "file"
main debug: translation test: code is "it"
main debug: looking for keystore module matching "memory": 4 candidates
main debug: using keystore module "memory"
main debug: CPU has capabilities FPU
main debug: Creating an input for 'Raccolta multimediale'
main debug: Input is a meta file: disabling unneeded options
main debug: using timeshift granularity of 50 MiB
main debug: using default timeshift path
main debug: `file/directory:///home/company/.local/share/vlc/ml.xspf' gives access `file' demux `directory' path `/home/company/.local/share/vlc/ml.xspf'
main debug: creating demux: access='file' demux='directory' location='/home/company/.local/share/vlc/ml.xspf' file='/home/company/.local/share/vlc/ml.xspf'
main debug: looking for access_demux module matching "file": 17 candidates
main debug: no access_demux modules matched
main debug: creating access: file:///home/company/.local/share/vlc/ml.xspf
main debug: (path: /home/company/.local/share/vlc/ml.xspf)
main debug: looking for access module matching "file": 28 candidates
main debug: using access module "filesystem"
main debug: looking for stream_filter module matching "prefetch,cache_read": 26 candidates
cache_read debug: Using stream method for AStream*
cache_read debug: starting pre-buffering
cache_read debug: received first data after 0 ms
cache_read debug: pre-buffering done 304 bytes in 0s - 5601 KiB/s
main debug: using stream_filter module "cache_read"
main debug: looking for stream_filter module matching "any": 26 candidates
playlist debug: using XSPF playlist reader
main debug: using stream_filter module "playlist"
main debug: stream filter added to 0x55905cf2d0
main debug: no stream_filter modules matched
main debug: looking for stream_directory module matching "any": 1 candidates
main debug: no stream_directory modules matched
main debug: attachment of directory-extractor failed for file:///home/company/.local/share/vlc/ml.xspf
main debug: looking for stream_filter module matching "record": 26 candidates
main debug: using stream_filter module "record"
main debug: looking for demux module matching "directory": 55 candidates
main debug: using demux module "directory"
main debug: looking for meta reader module matching "any": 2 candidates
lua debug: Trying Lua scripts in /home/company/.local/share/vlc/lua/meta/reader
lua debug: Trying Lua scripts in /usr/lib/aarch64-linux-gnu/vlc/lua/meta/reader
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/meta/reader/filename.luac
lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
main debug: no meta reader modules matched
main debug: `file/directory:///home/company/.local/share/vlc/ml.xspf' successfully opened
main debug: looking for xml reader module matching "any": 1 candidates
main debug: using xml reader module "xml"
main debug: EOF reached
main debug: removing module "directory"
main debug: removing module "record"
main debug: removing module "playlist"
main debug: removing module "cache_read"
main debug: removing module "filesystem"
main debug: creating audio output
main debug: looking for audio output module matching "any": 6 candidates
vlcpulse debug: using library version 11.1.0
vlcpulse debug: (compiled with version 11.1.0, protocol 32)
vlcpulse debug: connected locally to unix:/run/user/1000/pulse/native as client #16
vlcpulse debug: using protocol 32, server protocol 32
pulse debug: adding sink 0: alsa_output.platform-70030000.hda.hdmi-stereo (Built-in Audio Digital Stereo (HDMI))
pulse debug: adding sink 1: alsa_output.platform-sound.analog-stereo (Built-in Audio Analog Stereo)
main debug: using audio output module "pulse"
main debug: keeping audio output
main debug: looking for interface module matching "dbus,none": 19 candidates
dbus debug: listening on dbus as: org.mpris.MediaPlayer2.vlc
main debug: using interface module "dbus"
main debug: no running VLC instance - continuing normally...
main debug: looking for interface module matching "hotkeys,none": 19 candidates
main debug: using interface module "hotkeys"
main debug: looking for interface module matching "globalhotkeys,none": 19 candidates
main debug: using interface module "xcb_hotkeys"
main: Esecuzione di vlc con l'interfaccia predefinita. Usa 'cvlc' per utilizzare vlc senza interfaccia.
main debug: looking for interface module matching "any": 19 candidates
dbus debug: Getting All properties
main debug: looking for extension module matching "any": 1 candidates
lua debug: Opening Lua Extension module
lua debug: Trying Lua scripts in /home/company/.local/share/vlc/lua/extensions
lua debug: Trying Lua scripts in /usr/lib/aarch64-linux-gnu/vlc/lua/extensions
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/extensions/VLSub.luac
lua debug: Scanning Lua script /usr/lib/aarch64-linux-gnu/vlc/lua/extensions/VLSub.luac
lua debug: Script /usr/lib/aarch64-linux-gnu/vlc/lua/extensions/VLSub.luac has the following capability flags: 0x5
lua debug: Trying Lua scripts in /usr/share/vlc/lua/extensions
main debug: using extension module "lua"
main debug: using interface module "qt"
main: playlist is empty
main debug: nothing to play
qt debug: Saving the advanced preferences
main debug: processing request item: jellyfish-3-mbps-hd-h264.mkv, node: Scaletta, skip: 0
main debug: rebuilding array of current - root Scaletta
main debug: rebuild done - 1 items, index 0
main debug: starting playback of new item
main debug: resyncing on jellyfish-3-mbps-hd-h264.mkv
main debug: jellyfish-3-mbps-hd-h264.mkv is at 0
main debug: creating new input thread
main debug: Creating an input for 'jellyfish-3-mbps-hd-h264.mkv'
main debug: requesting art for new input thread
qt debug: IM: Setting an input
main debug: looking for meta fetcher module matching "any": 1 candidates
lua debug: Trying Lua scripts in /home/company/.local/share/vlc/lua/meta/fetcher
lua debug: Trying Lua scripts in /usr/lib/aarch64-linux-gnu/vlc/lua/meta/fetcher
lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/fetcher
main debug: no meta fetcher modules matched
main debug: looking for art finder module matching "any": 2 candidates
lua debug: Trying Lua scripts in /home/company/.local/share/vlc/lua/meta/art
lua debug: Trying Lua scripts in /usr/lib/aarch64-linux-gnu/vlc/lua/meta/art
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/meta/art/00_musicbrainz.luac
lua debug: skipping script (unmatched scope) /usr/lib/aarch64-linux-gnu/vlc/lua/meta/art/00_musicbrainz.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/meta/art/01_googleimage.luac
lua debug: skipping script (unmatched scope) /usr/lib/aarch64-linux-gnu/vlc/lua/meta/art/01_googleimage.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/meta/art/02_frenchtv.luac
lua debug: skipping script (unmatched scope) /usr/lib/aarch64-linux-gnu/vlc/lua/meta/art/02_frenchtv.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/meta/art/03_lastfm.luac
lua debug: skipping script (unmatched scope) /usr/lib/aarch64-linux-gnu/vlc/lua/meta/art/03_lastfm.luac
lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
main debug: no art finder modules matched
main debug: `file:///home/company/Scaricati/jellyfish-3-mbps-hd-h264.mkv' gives access `file' demux `any' path `/home/company/Scaricati/jellyfish-3-mbps-hd-h264.mkv'
main debug: creating demux: access='file' demux='any' location='/home/company/Scaricati/jellyfish-3-mbps-hd-h264.mkv' file='/home/company/Scaricati/jellyfish-3-mbps-hd-h264.mkv'
main debug: creating access: file:///home/company/Scaricati/jellyfish-3-mbps-hd-h264.mkv
main debug: (path: /home/company/Scaricati/jellyfish-3-mbps-hd-h264.mkv)
cache_read debug: pre-buffering done 1024 bytes in 0s - 13157 KiB/s
lua debug: Trying Lua scripts in /home/company/.local/share/vlc/lua/playlist
lua debug: Trying Lua scripts in /usr/lib/aarch64-linux-gnu/vlc/lua/playlist
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/anevia_streams.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/anevia_xml.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/appletrailers.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/bbc_co_uk.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/cue.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/dailymotion.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/jamendo.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/koreus.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/liveleak.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/newgrounds.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/rockbox_fm_presets.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/soundcloud.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/twitch.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/vimeo.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/vocaroo.luac
lua debug: Trying Lua playlist script /usr/lib/aarch64-linux-gnu/vlc/lua/playlist/youtube.luac
lua debug: Trying Lua scripts in /usr/share/vlc/lua/playlist
main debug: attachment of directory-extractor failed for file:///home/company/Scaricati/jellyfish-3-mbps-hd-h264.mkv
main debug: looking for demux module matching "mkv": 55 candidates
mkv debug: | + Seek head
mkv debug: | - info at 4151
mkv debug: | + Information
mkv debug: | | + TimecodeScale=1000000
mkv debug: | | + Muxing Application=libebml v1.2.0 + libmatroska v1.1.0
mkv debug: | | + Writing Application=mkvmerge v4.7.0 ('Just Like You Imagined') built on Apr 21 2011 01:13:14
mkv debug: | | + Duration=30030
mkv debug: | | + Date=Sa Feb 06 03:58:03 2016
mkv debug: | | + UID=-1981406324
mkv debug: | - tracks at 4314
mkv debug: | + Tracks
mkv debug: | | + Track Entry
mkv debug: | | | + Track Number=1
mkv debug: | | | + Track UID=2585299895
mkv debug: | | | + Track Type=video
mkv debug: | | | + Track Lacing=0
mkv debug: | | | + Track MinCache=1
mkv debug: | | | + Track CodecId=V_MPEG4/ISO/AVC
mkv debug: | | | + Track CodecPrivate size=66
mkv debug: | | | + Track Default Duration=33366665
mkv debug: | | | + Track Video
mkv debug: | | | | + width=1920
mkv debug: | | | | + height=1080
mkv debug: | | | | + display width=1920
mkv debug: | | | | + display height=1080
mkv debug: | - cues at 11202112
mkv debug: | + Cues
mkv debug: MKV/Ebml Parser: m_el[mi_level] == NULL
mkv debug: | - loading cues done.
mkv debug: | + Cluster
mkv debug: NEW START CHAPTER uid=0
mkv debug: found 1 es
main debug: selecting program id=0
mkv debug: seek: preroll{ track: 1, pts: 0, fpos: 5523 skip: 5523}
mkv debug: seek: preroll{ req: 1, start-pts: 1, start-fpos: 5523}
mkv debug: Starting the UI Hook
main debug: using demux module "mkv"
main debug: looking for a subtitle file in /home/company/Scaricati/
main debug: looking for video decoder module matching "any": 15 candidates
omxil debug: fmt in:h264, out:
omxil debug: component OMX.Nvidia.raw.read
omxil debug: - role: raw_reader.binary
omxil debug: component OMX.Nvidia.audio.read
omxil debug: - role: audio_reader.binary
omxil debug: component OMX.Nvidia.video.read
omxil debug: - role: video_reader.binary
omxil debug: component OMX.Nvidia.image.read
omxil debug: - role: image_reader.binary
omxil debug: component OMX.Nvidia.video.read.large
omxil debug: component OMX.Nvidia.video.scheduler
omxil debug: - role: video_scheduler.binary
omxil debug: component OMX.Nvidia.clock.component
omxil debug: - role: clock.binary
omxil debug: component OMX.Nvidia.raw.write
omxil debug: - role: raw_writer.binary
omxil debug: component OMX.Nvidia.audio.write
omxil debug: - role: audio_writer.binary
omxil debug: component OMX.Nvidia.video.write
omxil debug: - role: video_writer.binary
omxil debug: component OMX.Nvidia.image.write
omxil debug: - role: image_writer.binary
omxil debug: component OMX.Nvidia.imagesequence.write
omxil debug: component OMX.Nvidia.vidhdr.write
omxil debug: component OMX.Nvidia.vidhdr.read
omxil debug: component OMX.Nvidia.mp4.write
omxil debug: - role: container_muxer.3gp
omxil debug: component OMX.Nvidia.wav.write
omxil debug: - role: wav_writer.binary
omxil debug: component OMX.Nvidia.amr.write
omxil debug: - role: amr_writer.binary
omxil debug: component OMX.Nvidia.h265.encoder
omxil debug: - role: video_encoder.hevc
omxil debug: - role: image_encoder.heic
omxil debug: component OMX.Nvidia.h264.encoder
omxil debug: - role: video_encoder.avc
omxil debug: component OMX.Nvidia.vp8.encoder
omxil debug: - role: video_encoder.vp8
omxil debug: - role: video_encoder.vpx
omxil debug: component OMX.Nvidia.vp9.encoder
omxil debug: component OMX.Nvidia.aac.decoder
omxil debug: - role: audio_decoder.eaacplus
omxil debug: - role: audio_decoder.aac
omxil debug: - role: audio_decoder.aac.secure
omxil debug: component OMX.Nvidia.adts.decoder
omxil debug: - role: audio_decoder.adts
omxil debug: component OMX.Nvidia.bsac.decoder
omxil debug: - role: audio_decoder.bsac
omxil debug: component OMX.Nvidia.wav.decoder
omxil debug: - role: audio_decoder.wav
omxil debug: component OMX.Nvidia.vorbis.decoder
omxil debug: - role: audio_decoder.vorbis
omxil debug: component OMX.Nvidia.amr.decoder
omxil debug: - role: audio_decoder.amrnb
omxil debug: component OMX.Nvidia.amrwb.decoder
omxil debug: - role: audio_decoder.amrwb
omxil debug: component OMX.Nvidia.jpeg.encoder
omxil debug: - role: image_encoder.jpeg
omxil debug: component OMX.Nvidia.jpeg.decoder
omxil debug: - role: image_decoder.jpeg
omxil debug: component OMX.Nvidia.std.iv_renderer.overlay.rgb565
omxil debug: - role: iv_renderer.rgb.overlay
omxil debug: component OMX.Nvidia.render.overlay.argb8888
omxil debug: - role: iv_renderer.argb8888.overlay
omxil debug: component OMX.Nvidia.std.iv_renderer.overlay.yuv420
omxil debug: - role: iv_renderer.yuv.overlay
omxil debug: component OMX.Nvidia.render.hdmi.overlay.yuv420
omxil debug: - role: iv_renderer.hdmi.yuv420
omxil debug: component OMX.Nvidia.render.lvds.overlay.yuv420
omxil debug: - role: iv_renderer.lvds.yuv420
omxil debug: component OMX.Nvidia.render.crt.overlay.yuv420
omxil debug: - role: iv_renderer.crt.yuv420
omxil debug: component OMX.Nvidia.render.hdmi.overlay.argb8888
omxil debug: component OMX.Nvidia.render.lvds.overlay.argb8888
omxil debug: component OMX.Nvidia.render.crt.overlay.argb8888
omxil debug: component OMX.Nvidia.render.tvout.overlay.yuv420
omxil debug: - role: iv_renderer.tvout.yuv420
omxil debug: component OMX.Nvidia.render.secondary.overlay.yuv420
omxil debug: - role: iv_renderer.secondary.yuv420
omxil debug: component OMX.Nvidia.audio.render
omxil debug: - role: audio_renderer.pcm
omxil debug: component OMX.Nvidia.amr.encoder
omxil debug: - role: audio_encoder.amrnb
omxil debug: component OMX.Nvidia.amrwb.encoder
omxil debug: - role: audio_encoder.amrwb
omxil debug: component OMX.Nvidia.aac.encoder
omxil debug: - role: audio_encoder.aac
omxil debug: component OMX.Nvidia.mp4.encoder
omxil debug: - role: video_encoder.mpeg4
omxil debug: component OMX.Nvidia.h263.encoder
omxil debug: - role: video_encoder.h263
omxil debug: component OMX.Nvidia.ilbc.encoder
omxil debug: - role: audio_encoder.ilbc
omxil debug: component OMX.Nvidia.asf.read
omxil debug: - role: container_demuxer.asf
omxil debug: component OMX.Nvidia.mp4.read
omxil debug: - role: container_demuxer.3gp
omxil debug: component OMX.Nvidia.mkv.read
omxil debug: - role: container_demuxer.mkv
omxil debug: component OMX.Nvidia.avi.read
omxil debug: - role: container_demuxer.avi
omxil debug: component OMX.Nvidia.wav.read
omxil debug: - role: container_demuxer.wav
omxil debug: component OMX.Nvidia.aac.read
omxil debug: - role: container_demuxer.aac
omxil debug: component OMX.Nvidia.reader
omxil debug: - role: container_demuxer.all
omxil debug: component OMX.Nvidia.video.extractor
omxil debug: component OMX.Nvidia.wav.encoder
omxil debug: - role: audio_encoder.wav
omxil debug: component OMX.Nvidia.render.loopback
omxil debug: - role: iv_renderer.loopback
omxil debug: component OMX.Nvidia.mp3.decoder
omxil debug: - role: audio_decoder.mp3
omxil debug: component OMX.Nvidia.mp2.decoder
omxil debug: - role: audio_decoder.mp2
omxil debug: component OMX.Nvidia.mp4ext.decode
omxil debug: - role: video_decoder.mpeg4
omxil debug: component OMX.Nvidia.mp4.decode
omxil debug: component OMX.Nvidia.h263.decode
omxil debug: - role: video_decoder.h263
omxil debug: component OMX.Nvidia.h264ext.decode
omxil debug: - role: video_decoder.avc
omxil debug: component OMX.Nvidia.h264.decode
omxil debug: component OMX.Nvidia.h264.decode.secure
omxil debug: - role: video_decoder.avc.secure
omxil debug: component OMX.Nvidia.h265.decode
omxil debug: - role: video_decoder.hevc
omxil debug: component OMX.Nvidia.h265.decode.secure
omxil debug: - role: video_decoder.hevc.secure
omxil debug: component OMX.Nvidia.vp8.decode
omxil debug: - role: video_decoder.vp8
omxil debug: - role: video_decoder.vpx
omxil debug: component OMX.Nvidia.vp9.decode
omxil debug: - role: video_decoder.vp9
omxil debug: component OMX.Nvidia.vp9.decode.secure
omxil debug: - role: video_decoder.vp9.secure
omxil debug: component OMX.Nvidia.vp9hdr.decode
omxil debug: component OMX.Nvidia.eaacp.decoder
omxil debug: component OMX.Nvidia.ac3.bypass.decoder
omxil debug: - role: audio_decoder.ac3
omxil debug: component OMX.Nvidia.dts.bypass.decoder
omxil debug: - role: audio_decoder.dts
omxil debug: component OMX.Nvidia.dtshd.bypass.decoder
omxil debug: - role: audio_decoder.dtshd
omxil debug: component OMX.Nvidia.truehd.bypass.decoder
omxil debug: - role: audio_decoder.truehd
omxil debug: component OMX.Nvidia.eac3.bypass.decoder
omxil debug: - role: audio_decoder.x-eac3
omxil debug: component OMX.Nvidia.wma.decoder
omxil debug: - role: audio_decoder.wma
omxil debug: component OMX.Nvidia.wmapro.decoder
omxil debug: - role: audio_decoder.wmapro
omxil debug: component OMX.Nvidia.wmalossless.decoder
omxil debug: - role: audio_decoder.wmalossless
omxil debug: component OMX.Nvidia.mjpeg.decoder
omxil debug: - role: video_decoder.mjpeg
omxil debug: component OMX.Nvidia.mpeg2v.decode
omxil debug: - role: video_decoder.mpeg2
omxil debug: component OMX.Nvidia.vc1.decode
omxil debug: - role: video_decoder.vc1
omxil debug: - role: video_decoder.wmv
omxil debug: component OMX.Nvidia.vc1.decode.secure
omxil debug: - role: video_decoder.vc1.secure
omxil debug: found 3 matching components for role video_decoder.avc
omxil debug: - OMX.Nvidia.h264ext.decode
omxil debug: - OMX.Nvidia.h264.decode
omxil debug: - OMX.Nvidia.h264.decode.secure
