I try to use CUDA for Windows 7 virtual machine running on an ESXi 5.0 from VMware.
I did all the steps mentioned on the blog of vmware
Currently, the Quadro 4000 is correctly seen by the guest system and I could install the nvidia driver. So I think the “virtualization” is no longer a problem.
However, vmware put up standard VGA cards virtual display system. My problem is that when I try to activate the TCC mode, the following message appears:
Unable to set driver model for GPU 0: B: 0: TCC can not Be Enabled for device with display.
Finally, I could activate TCC by using the following command
nvidia-smi.exe -fdm 1
OpenCL works well on Windows 7 virtualized with ESXi 5.0.
Now is there an explanation for when I use the command:
nvidia-smi.exe -L
under windows server 2008 R2 virtualized it lists no card, while the driver is installed and the card appears well in the list of equipment installed on the server.
just fyi: We couldn’t get CUDA to work in our virtualized environment (VMWare ESX 5, Windows Server 2008). We triead a Tesla C0275 and a Quadro 2000, didn’t succeed with any of those GPUs.
