I have a server box that I want to augment with the Tesla C1060 processor.
When I just use the built-in VGA adapter (AST2050), I can’t run any of the SDK samples as they say there is no CUDA capable card installed. A look at device manager shows the C1060 using the driver that is part of the 2.3 kit is recognized by the OS.
When I plug in an Nvidia display adapter in a spare slot (older-not CUDA capable but uses the same installed driver), I can run all the samples just fine as the C1060 is now accessible.
Does anyone know how I can configure Windows Server 2008 and/or Nvidia driver/CUDA toolkit SW to allow me access to the C1060 when I am only using the built-in VGA adapter?
I’d hate to have to include an extra adapter for no good reason plus lose PCIe slots I need for network adapters.
Jeff, the Windows display driver model only supports one driver to be loaded at any one time – so when you’re using the normal VGA slot and using that driver, you can’t use CUDA. By plugging in the extra adapter, you’re loading the nVidia driver, which makes both cards work.
I understand that this may be fixed in Windows Server 2008 R2, but I’m not sure (I know they made some driver model changes, but I don’t know if they made it into the RTM or not).
Can you tell me the vendor and device ID of the display chip in the Supermicro 1U? I haven’t been able to get my hands on one, and I’ve been trying to figure out if the display card has XPDM or WDDM drivers.
Running 4 S1070 HIC controllers @ PCI x16.2 on a Tyan S7025, vchip is Aspeed AST2050
I found a PCI (32bit) 8400GS and slipped it in, but now I’m wondering if my MOBO can handle that, sometimes they will deactivate or modify the PCI electrical
bet there is something in the BIOS to set this manually
Will this apply to Windows 7 x64 as well? I have tried the latest driver for Windows 7 but still cannot get the C1060 to work correctly without a Nvidia adapter.
