Vs code isaac sim debug working but run not working
from isaacsim import SimulationApp
simulation_app = SimulationApp({"headless": False, "open_usd": "/home/ibra/.local/share/ov/pkg/isaac-sim-4.2.0/usdProject/myProject.usd"})
from omni.isaac.core import World
my_world = World(stage_units_in_meters=1.0)
while simulation_app.is_running():
    my_world.step(render=True)
simulation_app.close()
This is my simple code. When I debug this code, the simulation works. But when I run it, I get the error module not found: isaacsim. To help you, I chose the python interpreter …/kit/python/bin/python3. And let me show you the launch.json, settings.json and tasks.json codes.
launch.json
    // Use IntelliSense to learn about possible attributes.
    // Hover to view descriptions of existing attributes.
    // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
    "version": "0.2.0",
    "configurations": [
            "name": "Python: Current File",
            "type": "debugpy",
            "request": "launch",
            "program": "${file}",
            "console": "integratedTerminal",
            "env": {
                "RESOURCE_NAME": "IsaacSim"
            "python": "${workspaceFolder}/kit/python/bin/python3",
            "envFile": "${workspaceFolder}/.vscode/.standalone_examples.env",
            "preLaunchTask": "setup_python_env"
            "name": "Python: Attach (windows-x86_64/linux-x86_64)",
            "type": "debugpy",
            "request": "attach",
            "port": 3000,
            "host": "localhost"
            "name": "(Linux) isaac-sim",
            "type": "debugpy",
            "program": "${workspaceFolder}/kit/kit",
            "args": ["${workspaceFolder}/apps/omni.isaac.sim.kit",
                "--ext-folder", "${workspaceFolder}/exts",
                "--ext-folder", "${workspaceFolder}/apps"],
            "stopAtEntry": false,
            "cwd": "${workspaceFolder}",
            "environment": [],
            "externalConsole": false,
            "MIMode": "gdb",
            "setupCommands": [
                    "description": "Enable pretty-printing for gdb",
                    "text": "-enable-pretty-printing",
                    "ignoreFailures": true
settings.json I’m only showing a part of it
   "python.languageServer": "Pylance",
    "python.defaultInterpreterPath": "${workspaceFolder}/kit/python/bin/python3",
    // python.pythonPath is deprecated
    // "python.pythonPath": "${workspaceFolder}/kit/python/python3",
    // This enables python language server. Seems to work slightly better than jedi:
    "python.jediEnabled": false,
    // We use "black" as a formatter:
    "python.formatting.provider": "black",
    "python.formatting.blackArgs": ["--line-length", "120"],
    // Use flake8 for linting
    "python.linting.pylintEnabled": false,
    "python.linting.flake8Enabled": true,
tasks.json
    // See https://go.microsoft.com/fwlink/?LinkId=733558
    // for the documentation about the tasks.json format
    "version": "2.0.0",
    "tasks": [
            "label": "setup_python_env",
            "type": "shell",
            "linux": {
                "command": "export CARB_APP_PATH=${workspaceFolder}/kit && export ISAAC_PATH=${workspaceFolder} && export EXP_PATH=${workspaceFolder}/apps && source ${workspaceFolder}/setup_python_env.sh && printenv >${workspaceFolder}/.vscode/.standalone_examples.env"
How can ı fix it?
Is this still an issue for you? If so, could you provide detailed steps to reproduce it?
