Wav format for A2F
Hi!
I am using A2F and A2F_controller and connecting them to unreal engine. When I use Animate from Wav, the file is sent successfully, but when its played in the engine; I can only hear white noise. This suggests that the format is invalid, but they are generated using Eleven Labs in the supported format, PCM at 16htz.
What could the issue be?
Hi @inhalet
A2F supoort has moved.
