When I select the custom directory containing my WAV files, it says no options available. If I add the file to the default directory, it doesn’t show up in the Track Name dropdown menu.
@fuselayer0 i am just another OV user, but one of the big issues I noticed after going through the log is the GPU you are using to run A2F. it appears you are currently using a GTX 1080 card while OV apps in general will require RTX hardware. so, audio file issue aside, your hardware will likely lead to A2F’s functionality issues.
you can take a look at the technical requirements for A2F app here and see if its feasible for you to get access to a RTX card and try again:
