What I am trying to do is to swap the default robot with Turtlebot 4 in the demo for Visual SLAM (Tutorial for Visual SLAM with Isaac Sim — isaac_ros_docs documentation). However, I noticed that the turtlebot 4 will keep slightly shaking after turning on the simulator. It won’t happen if I load Turtlebot 4 and create a ground plane and physcis scene (the simplest scene), which means the issue doesn’t come from the robot model. I wonder how I should address this issue. Any hints are appreciated!
Related topics
Topic | Replies | Views | Activity | |
Issue on VSLAM with Isaac Sim | 9 | 471 | March 13, 2025 | |
Isaac ROS Visual-Slam Error with IsaacSim4.1 | 2 | 44 | October 29, 2024 | |
Isaac Sim 4-wheel robot sliding issue | 1 | 881 | August 18, 2023 | |
My Basic Simple Turtle bot can't move straight | 0 | 44 | February 24, 2025 | |
Modify existing tutorial to use other robots (solved) | 2 | 310 | November 30, 2023 | |
[visual_slam_node]: Transform is impossible. canTransform(base_link->front_stereo_camera_left_optical) returns false | 10 | 358 | September 6, 2024 | |
Running VSLAM with Issac sim | 3 | 69 | April 1, 2025 | |
Errors Following Tutorial for Drive TurtleBot: Seeking Solutions | 2 | 65 | October 7, 2024 | |
Driving jebot in the warehouse which I created will shake up and down | 6 | 496 | June 17, 2022 | |
ROS camera is shaking in rviz | 1 | 667 | April 5, 2024 |
