Weird message showed up when running any code
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: NVIDIA GeForce RTX 3090 Ti
  • Driver Version: 535.183.01
Topic Description
Detailed Description
Since last week, every time I run anything inside Isaac Sim, it shows a bunch of INFO messages for no reason. Tried restarting the computer.
Steps to Reproduce
isaacsim isaacsim.exp.full.kit
Run any example from the menu after loading Isaac Sim
Error Messages
2025-04-16T22:23:56.404213Z INFO hub-003 ThreadId(14) lru_task:lru_update: hub_cache::block::cache: hub-cache/src/block/cache.rs:1320: return=Ok(())
2025-04-16T22:25:31.574377Z INFO hub-000 ThreadId(11) lru_task:lru_update: hub_cache::block::cache: hub-cache/src/block/cache.rs:1320: return=Ok(())
2025-04-17 16:36:55 [256ms] [Warning] [carb.omniclient.plugin] 11021: OmniHub: ThreadId(03) Hub encountered error. Trying to reconnect to Hub. retry_reason="Io(\"Connection reset by peer (os error 104)\")"
Screenshots or Videos
Did you update anything last week? Do you still observe this if running Isaac Sim with the --reset-user option?
I did not update anything.
Could you explain more on how to use --reset-user or are there any documents for that?
Please refer to the user config mentioned in Configuration — Omniverse Kit.
Can it resolve the issue?
It happens from time to time for no reason
Could you try reducing the amount of log output by using the following command-line arguments:
--/log/level=error --/log/fileLogLevel=error --/log/outputStreamLevel=error
Hello!
Best regards,
