Default units of Isaac Sim is meter, while other Omniverse apps as centimeter.
I used USD Unit Converter, because I want to edit a USD file made at Create in Isaac Sim with maintaining same scale.
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/ext_omni_isaac_unit_converter.html
First, I made a cube has 1 x 1 x 1 cm with Create.
But after I opened that file with Isaac Sim and applied Unit Converter (enter “New Meters per Unit” and press “PROCESS”), Measure Tool still showed 100 x 100 x 100 cm.
Is Unit Converter what changes scale of objects in a lump?
If I want to edit USD in Isaac Sim with same scale with other Omniverse apps, I should transform magnification as x 0.01 for each objects?
Additionally, USD has no absolute size information?
I think a object in USD file shows different absolute sizes for each Omniverse apps.
Thank you for your kindly support.
