What is the minimum GPU's clock frequency for all the nvpmodel modes?
Hi
I am checking the GPU’s clock frequency. Is it wise to say that all the modes (MAX-N, MAX-Q, MAX-P) has 114MHz as the minimum frequency? And that the max frequency is the one that can be seen in the table?
hello Aizzaac,
you’re correct to check from system nodes for the available clock rates,
please refer to Supported Modes and Power Efficiency for the default NVPModel clock configurations.
thanks
I checked using “jetson_clocks”. The default minimum memory for all the models is 114MHz.
MAXQ
MAXN
