When decodeing rtsp stream with nvv4l2decoder block
Hello, I am in the latest version Jetpack 4.5 on Jeston NX, when i using nvv4l2decoder to decode some rtsp stream, the pipeline was blocked, the pipeline is:
gst-launch-1.0 rtspsrc location=rtsp://192.168.10.108:554/stream=0 ! rtph264depay ! nvv4l2decoder ! fakesink dump=true
nvbuf_utils: Could not get EGL display connection
Setting pipeline to PAUSED …
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://192.168.10.108:554/stream=0
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
The pipeline is blcoking, and NVDEC is not working.
I also tried to add h264parse after nvv4l2decoder plugin.I am sure this rtsp server is working, because removing nvv4l2decoder the pipeline worked,
When i using another rtsp stream or the media file to right, the pipeline is right.
Looks like it is running. The sink is fakesink, so nothing is shown.
Please try uridecodebin:
gst-launch-1.0 uridecodebin uri='rtsp://192.168.10.108:554/stream=0 ' ! nvoverlaysink
