Where can i get the counterplug of the AC0002-0011-001-HH used in the jetson orin agx devkit not even the manufacturer has listet the dc power jack.
I also wasn’t able to find an dc power jack with the matching specifications of 20V 8A for a 5.5mm 2.5mm dc power plug.
Please send me the link or the part number of an shop with an compatible plug.
Thanks, but I’m searching for the connector alone and as much as i could find this connector only supports 5A
Edit: according to your comment DC power jack specification the onboard connector supports 8A which is relevant since our system is built on 12v and uses also a pcie extender card.
We tought about soldering another connector to the board but this is no option because we would loose the warranty of our unit.
