GPIO lines are attached to gpiochips. Look in /sys/class/gpio and you should see gpiochip240, 248, and 288. I haven’t yet determined which GPIOs are connected to 240.
If you download the pinmux spreadsheet and unhide column G you’ll see GPIO names like GPIO3_PA.00. Ignore the GPIO3_P portion, the A.00 is the important part. The alpha portion is the port, the numeric is the IO in the port. Some ports have a double alpha designation, like AA. Single alphas are attached to gpiochip288 while double alphas are on gpiochip248.
Take the alpha portion as a number (A=0, B=1, …) and multiply by 8 then add the numeric value. Finally add the gpiochip number. For double alphas AA=0, BB=1, …
e.g. GPIO3_PG.02: Single alpha so the gpiochip is 288, G = 6. So we have 288 + 6 * 8 + 2 = 338
Back to the spreadsheet, column A has the signal name and column B has the ball number. The expansion header is labelled with the signal name. The signal name for GPIO3_PG.02 is GPIO28.
