Where to download sample data in nvmedia samples
Software Version
[*] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
1.9.2.10884
[*] other
Host Machine Version
[*] native Ubuntu Linux 18.04 Host installed with DRIVE OS Docker Containers
other
I cannot find where to download sample data about samples in nvmedia modules. For example, in nvmedia/img_ldc/ldc_apply_warpmap.conf, there is a inputFile = “tmp/fisheye_1280x800_420_60frames.yuv” configure, but I cannot find any sample data called fisheye_1280x800_420_60frames.yuv
Please check if this file on the target system helps.
/opt/nvidia/drive-linux/samples/Media/fisheye_1280_1080_yuv420.yuv
I have found this file. However, the InputFile in iep/simple_vp9_cif.cfg is NTSC352x240.yv12. I cannot find a file called *.yv12.
Files referenced in the cfg files may be not included in the release. To address this issue, kindly adjust the configuration file and use your own input file instead.
OK,Thanks!In order to quick start the sample codes for developers, it is recommended to put all data which related to the sample codes on the cloud for download.
