After the newly flashed AGX board comes up, I see two dtb files, one in /boot and the other in /boot/dtb/. They have different checksum. Which is the correct one? Why do we have two?
If you didn’t configure anything inside your extlinux.conf, then none of them is in use. The one that is in use is inside kernel dtb partition.
I need to configure extlinux.conf, so want to know which of the two dtb files I should point FDT to .
Use that one inside /boot/dtb.
