this is my code:
from omni.isaac.examples.base_sample import BaseSample
from omni.isaac.franka import Franka
from omni.isaac.core.objects import DynamicCuboid
from omni.isaac.franka.controllers import PickPlaceController,RMPFlowController
import numpy as np
from omni.isaac.core.prims import XFormPrim
from omni.isaac.core.utils.numpy.rotations import euler_angles_to_quats
from omni.isaac.core.utils.stage import add_reference_to_stage
from omni.isaac.core.utils.nucleus import get_assets_root_path
class HelloWorld(BaseSample):
def __init__(self) -> None:
super().__init__()
return
def setup_scene(self):
world = self.get_world()
world.scene.add_default_ground_plane()
franka = world.scene.add(Franka(prim_path="/World/Fancy_Franka", name="fancy_franka"))
# franka.get_joints_state(franka.get_joints_default_state())
world.scene.add(
DynamicCuboid(
prim_path="/World/random_cube",
name="fancy_cube",
position=np.array([0.3, 0.3, 0.3]),
scale=np.array([0.0515, 0.0515, 0.0515]),
color=np.array([0, 0, 1.0]),
# add_reference_to_stage(get_assets_root_path() + "/Isaac/Props/UIElements/frame_prim.usd", "/World/target")
# self._target = XFormPrim("/World/target", scale=[.04,.04,.04])
# self._target.set_default_state(np.array([.3,0,.5]),euler_angles_to_quats([0,0,0]))
return
async def setup_post_load(self):
self._world = self.get_world()
self._franka = self._world.scene.get_object("fancy_franka")
self._fancy_cube = self._world.scene.get_object("fancy_cube")
self._controller = RMPFlowController(name=f"controller", robot_articulation=self._franka)
self._world.add_physics_callback("sim_step", callback_fn=self.physics_step)
# World has pause, stop, play..etc
# Note: if async version exists, use it in any async function is this workflow
self._franka.gripper.set_joint_positions(self._franka.gripper.joint_opened_positions)
await self._world.play_async()
return
# This function is called after Reset button is pressed
# Resetting anything in the world should happen here
async def setup_post_reset(self):
self._controller.reset()
return
def physics_step(self, step_size):
target_position, target_orientation = self._fancy_cube.get_world_pose()
actions = self._controller.forward(
target_end_effector_position=target_position,
target_end_effector_orientation=target_orientation,
self._franka.apply_action(actions)
return
and I get weird pose.
