I followed deepstream-image-meta-test. In the original sample, I can save image using osd probe.
deepstream-image-meta-test is used using my trained model for Plate detection for my application.
Then tried to save image of plate. But I can save only green color image like below.
I can see that bounding boxes are correct and accurate from display.
The following link is the one which save image in osd probe.
if (frame_number < 100 && obj_meta->class_id == PGIE_CLASS_ID_PLATE) {
NvDsUserMetaList *usrMetaList = obj_meta->obj_user_meta_list;
FILE *file;
while (usrMetaList != NULL) {
NvDsUserMeta *usrMetaData = (NvDsUserMeta *) usrMetaList->data;
if (usrMetaData->base_meta.meta_type == NVDS_CROP_IMAGE_META) {
NvDsObjEncOutParams *enc_jpeg_image = (NvDsObjEncOutParams *) usrMetaData->user_meta_data;
/* Write to File */
file = fopen (fileNameString, "wb");
fwrite (enc_jpeg_image->outBuffer, sizeof (uint8_t), enc_jpeg_image->outLen, file);
fclose (file);
usrMetaList = NULL;
} else {
usrMetaList = usrMetaList->next;
I am using Deepstream 5.0 and AGX Xavier.
