WIFI disconnect on Jetson Thor - random disconnect
🛑 Jetson Thor (JetPack 7 / Ubuntu 24.04) – RTL8852CE WiFi crashes
Platform
Component Value
Board Jetson Thor
JetPack 7 (L4T R36 / R38, Ubuntu 24.04)
WiFi Realtek RTL8852CE (PCIe, 802.11ax)
Kernel 6.8.12-tegra
Driver rtl8852ce v1.19.16_nv-126-10-g6784793e9 (NVIDIA-certified)
❗ Symptoms
After random uptime (minutes → hours) WiFi becomes completely unusable:
  • Endless reconnect loops
  • Association request to the driver failed
  • CTRL-EVENT-ASSOC-REJECT status_code=8
  • Eventually the interface becomes permanently broken until reboot
🧨 Kernel errors at failure
The failure is always preceded by IOMMU queue collapse:
arm-smmu-v3 ... EVTQ overflow detected -- events lost
Immediately followed by RTL8852CE reconnect storms and wpa_supplicant failures.
🔧 Mitigations already applied (no effect)
PCIe / Power Management
  • PCIe ASPM fully disabled
pcie_aspm=off
* Runtime PM disabled on device
/sys/bus/pci/devices/.../power/control = on
Realtek driver power saving fully disabled
options rtw8852ce disable_aspm=1
options rtw8852ce disable_lps_deep=1
options rtw8852ce power_save=0
options rtw8852ce ips=0
Userspace
  • NetworkManager WiFi powersave disabled
  • Udev rules forcing PCI power to on
➡️ Issue still reproduces reliably after several hours.
🧠 Strong indicators
  • Failures are tightly correlated with ARM SMMU EVTQ overflow
  • RTL8852CE appears to leak or spam DMA faults
  • SMMU event queue eventually overflows → device becomes unrecoverable
  • Only a full reboot restores WiFi
This strongly points to a DMA/IOMMU bug in the RTL8852CE driver on Thor (T264).
📦 System / L4T version
# R38 (release), REVISION: 2.2, GCID: 42205042, BOARD: generic, EABI: aarch64
# DATE: Thu Sep 25 22:47:11 UTC 2025
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
nvidia-l4t-core 38.2.2-20250925153837
❓ Request to NVIDIA
  • Is RTL8852CE known to have SMMU / DMA issues on Thor (T264)?
  • Is there a newer driver drop or kernel patch that fixes EVTQ overflow?
  • Is an IOMMU passthrough / non-translated mode recommended for WiFi on Thor?
This currently makes Jetson Thor unsuitable for long-running headless deployments. If no reply until 05th Jan 2026 - the device must be returned to store.
You might find some of the information in this post helpful.
Thank you for the link - I already saw this - but fixes it only for some time - the interval got longer but still breaks after several hours, esp. when Thor is running without load.
There are hints that this causes instability on Thor - can NVIDIA confirm this and have a passthrough solution?
~0121
Do you see any error message in dmesg? Please attach dmesg log(from booting) for reference.
