This is the error you encountered when running tensorflow-gpu: “loaded cudnn version 8901 could not load library zlibwapi.dll. error code 193. please verify that the library is built correctly for your processor architecture (32-bit, 64-bit)”. You’re using Windows 11 with tensorflow-gpu==2.10.0, cuda==12.1, and cudnn==8.9.1. I want to ask you guys how to solve this problem. Thank you!
I tried it, but I still get this error
I did it with reference to this webpage, but it is still wrong,Is there any other way to solve it?
After rebooting several times, it suddenly worked, thanks!
