With lt6911c HDMI-CSI, Video resolution other than 1920*1080 cannot be obtained
$v4l2-ctl --verbose --set-fmt-video=width=1280,height=1024,pixelformat=UYVY --stream-mmap --stream-count=100 -d /dev/video0 --stream-to=test.raw
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : ‘UYVY’
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
VIDIOC_DQBUF: failed: Input/output error
VIDIOC_STREAMOFF: ok
cat /sys/kernel/debug/tracing/trace_pipe
kworker/2:0-10172 [002] … 12922.596789: rtos_queue_peek_from_isr_failed: tstamp:404070553050 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12922.764722: rtos_queue_peek_from_isr_failed: tstamp:404075553044 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12922.932736: rtos_queue_peek_from_isr_failed: tstamp:404080553037 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12923.100726: rtos_queue_peek_from_isr_failed: tstamp:404085553031 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12923.268719: rtos_queue_peek_from_isr_failed: tstamp:404090553026 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12923.436702: rtos_queue_peek_from_isr_failed: tstamp:404095553019 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12923.604721: rtos_queue_peek_from_isr_failed: tstamp:404100553009 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12923.716767: rtos_queue_peek_from_isr_failed: tstamp:404105553004 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12923.884731: rtos_queue_peek_from_isr_failed: tstamp:404110552997 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12924.052750: rtos_queue_peek_from_isr_failed: tstamp:404115552991 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12924.220722: rtos_queue_peek_from_isr_failed: tstamp:404120552985 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12924.388749: rtos_queue_peek_from_isr_failed: tstamp:404125552979 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12924.556721: rtos_queue_peek_from_isr_failed: tstamp:404130552973 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12924.724754: rtos_queue_peek_from_isr_failed: tstamp:404135552965 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12924.836779: rtos_queue_peek_from_isr_failed: tstamp:404140552955 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12925.004744: rtos_queue_peek_from_isr_failed: tstamp:404145552950 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12925.172784: rtos_queue_peek_from_isr_failed: tstamp:404150552944 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12925.340763: rtos_queue_peek_from_isr_failed: tstamp:404155552937 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12925.508752: rtos_queue_peek_from_isr_failed: tstamp:404160552931 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12925.676892: rtos_queue_peek_from_isr_failed: tstamp:404165552925 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12925.844754: rtos_queue_peek_from_isr_failed: tstamp:404170552916 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12925.956768: rtos_queue_peek_from_isr_failed: tstamp:404175552913 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12926.124816: rtos_queue_peek_from_isr_failed: tstamp:404180552903 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12926.292796: rtos_queue_peek_from_isr_failed: tstamp:404185552893 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12926.460804: rtos_queue_peek_from_isr_failed: tstamp:404190552889 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12926.628837: rtos_queue_peek_from_isr_failed: tstamp:404195552883 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12926.796822: rtos_queue_peek_from_isr_failed: tstamp:404200552875 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12926.965049: rtos_queue_peek_from_isr_failed: tstamp:404205552869 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12927.076771: rtos_queue_peek_from_isr_failed: tstamp:404210552861 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12927.244801: rtos_queue_peek_from_isr_failed: tstamp:404214402284 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12939.732887: rtos_queue_peek_from_isr_failed: tstamp:404604997449 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12939.732948: rtcpu_start: tstamp:404604999547
kworker/2:0-10172 [002] … 12939.732957: rtos_queue_send_from_isr_failed: tstamp:404605011608 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.732963: rtos_queue_send_from_isr_failed: tstamp:404605011715 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12939.732968: rtos_queue_send_from_isr_failed: tstamp:404605011822 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12939.732973: rtos_queue_send_from_isr_failed: tstamp:404605011932 queue:0x0b4af718
kworker/2:0-10172 [002] … 12939.732979: rtos_queue_send_from_isr_failed: tstamp:404605012036 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12939.732984: rtos_queue_send_from_isr_failed: tstamp:404605012138 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12939.733064: rtos_queue_send_from_isr_failed: tstamp:404605012243 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12939.733081: rtos_queue_send_failed: tstamp:404605012707 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.733086: rtos_queue_send_from_isr_failed: tstamp:404605018314 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.733092: rtos_queue_send_from_isr_failed: tstamp:404605018423 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12939.733097: rtos_queue_send_from_isr_failed: tstamp:404605018531 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12939.733102: rtos_queue_send_from_isr_failed: tstamp:404605018640 queue:0x0b4af718
kworker/2:0-10172 [002] … 12939.733108: rtos_queue_send_from_isr_failed: tstamp:404605018745 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12939.733113: rtos_queue_send_from_isr_failed: tstamp:404605018856 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12939.733118: rtos_queue_send_from_isr_failed: tstamp:404605018961 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12939.733124: rtos_queue_send_failed: tstamp:404605019900 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.733131: rtcpu_vinotify_event: tstamp:404605076827 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:404605076438 data:0x00010000
kworker/2:0-10172 [002] … 12939.733136: rtcpu_vinotify_event: tstamp:404605272550 tag:CHANSEL_PXL_SOF channel:0x00 frame:33917 vi_tstamp:404605271801 data:0x00000001
kworker/2:0-10172 [002] … 12939.733142: rtcpu_vinotify_event: tstamp:404605272721 tag:ATOMP_FS channel:0x00 frame:33917 vi_tstamp:404605271809 data:0x00000000
kworker/2:0-10172 [002] … 12939.733147: rtcpu_vinotify_event: tstamp:404605272839 tag:CHANSEL_FAULT channel:0x00 frame:33917 vi_tstamp:404605272118 data:0x00000200
kworker/2:0-10172 [002] … 12939.733152: rtcpu_vinotify_event: tstamp:404605273710 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:33917 vi_tstamp:404605272980 data:0x08000000
kworker/2:0-10172 [002] … 12939.733158: rtcpu_vinotify_event: tstamp:404605273819 tag:CHANSEL_FAULT_FE channel:0x10 frame:33917 vi_tstamp:404605272983 data:0x00000001
kworker/2:0-10172 [002] … 12939.733163: rtcpu_vinotify_event: tstamp:404605273962 tag:ATOMP_FE channel:0x00 frame:33917 vi_tstamp:404605272986 data:0x00000000
kworker/2:0-10172 [002] … 12939.900973: rtos_queue_peek_from_isr_failed: tstamp:404609997791 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12939.956946: rtos_queue_send_from_isr_failed: tstamp:404612160538 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.957018: rtos_queue_send_from_isr_failed: tstamp:404612160670 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12939.957027: rtos_queue_send_from_isr_failed: tstamp:404612160779 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12939.957035: rtos_queue_send_from_isr_failed: tstamp:404612160888 queue:0x0b4af718
kworker/2:0-10172 [002] … 12939.957043: rtos_queue_send_from_isr_failed: tstamp:404612160993 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12939.957074: rtos_queue_send_from_isr_failed: tstamp:404612161098 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12939.957084: rtos_queue_send_from_isr_failed: tstamp:404612161203 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12939.957198: rtos_queue_send_failed: tstamp:404612161760 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.957208: rtos_queue_send_from_isr_failed: tstamp:404612164394 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.957218: rtos_queue_send_from_isr_failed: tstamp:404612164501 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12939.957228: rtos_queue_send_from_isr_failed: tstamp:404612164606 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12939.957236: rtos_queue_send_from_isr_failed: tstamp:404612164720 queue:0x0b4af718
kworker/2:0-10172 [002] … 12939.957243: rtos_queue_send_from_isr_failed: tstamp:404612164824 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12939.957252: rtos_queue_send_from_isr_failed: tstamp:404612164927 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12939.957259: rtos_queue_send_from_isr_failed: tstamp:404612165035 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12939.957267: rtos_queue_send_failed: tstamp:404612165469 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.957274: rtos_queue_send_from_isr_failed: tstamp:404612686035 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.957281: rtos_queue_send_from_isr_failed: tstamp:404612686142 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12939.957288: rtos_queue_send_from_isr_failed: tstamp:404612686248 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12939.957295: rtos_queue_send_from_isr_failed: tstamp:404612686356 queue:0x0b4af718
kworker/2:0-10172 [002] … 12939.957303: rtos_queue_send_from_isr_failed: tstamp:404612686461 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12939.957310: rtos_queue_send_from_isr_failed: tstamp:404612686566 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12939.957317: rtos_queue_send_from_isr_failed: tstamp:404612686671 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12939.957324: rtos_queue_send_failed: tstamp:404612687120 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.957332: rtos_queue_send_from_isr_failed: tstamp:404612689913 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.957339: rtos_queue_send_from_isr_failed: tstamp:404612690019 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12939.957346: rtos_queue_send_from_isr_failed: tstamp:404612690127 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12939.957353: rtos_queue_send_from_isr_failed: tstamp:404612690236 queue:0x0b4af718
kworker/2:0-10172 [002] … 12939.957360: rtos_queue_send_from_isr_failed: tstamp:404612690341 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12939.957369: rtos_queue_send_from_isr_failed: tstamp:404612690446 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12939.957378: rtos_queue_send_from_isr_failed: tstamp:404612690552 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12939.957387: rtos_queue_send_failed: tstamp:404612691488 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12939.957396: rtcpu_vinotify_event: tstamp:404613082209 tag:CHANSEL_PXL_SOF channel:0x00 frame:33932 vi_tstamp:404613081460 data:0x00000001
kworker/2:0-10172 [002] … 12939.957408: rtcpu_vinotify_event: tstamp:404613082380 tag:ATOMP_FS channel:0x00 frame:33932 vi_tstamp:404613081466 data:0x00000000
kworker/2:0-10172 [002] … 12939.957417: rtcpu_vinotify_event: tstamp:404613082494 tag:CHANSEL_FAULT channel:0x00 frame:33932 vi_tstamp:404613081777 data:0x00000200
kworker/2:0-10172 [002] … 12939.957425: rtcpu_vinotify_event: tstamp:404613083364 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:33932 vi_tstamp:404613082635 data:0x08000000
kworker/2:0-10172 [002] … 12939.957434: rtcpu_vinotify_event: tstamp:404613083478 tag:CHANSEL_FAULT_FE channel:0x10 frame:33932 vi_tstamp:404613082637 data:0x00000001
kworker/2:0-10172 [002] … 12939.957444: rtcpu_vinotify_event: tstamp:404613083624 tag:ATOMP_FE channel:0x00 frame:33932 vi_tstamp:404613082640 data:0x00000000
kworker/2:0-10172 [002] … 12940.013071: rtos_queue_peek_from_isr_failed: tstamp:404614997784 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12940.180974: rtos_queue_send_from_isr_failed: tstamp:404619949121 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.181037: rtos_queue_send_from_isr_failed: tstamp:404619949231 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12940.181046: rtos_queue_send_from_isr_failed: tstamp:404619949339 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12940.181053: rtos_queue_send_from_isr_failed: tstamp:404619949446 queue:0x0b4af718
kworker/2:0-10172 [002] … 12940.181076: rtos_queue_send_from_isr_failed: tstamp:404619949550 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12940.181084: rtos_queue_send_from_isr_failed: tstamp:404619949655 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12940.181091: rtos_queue_send_from_isr_failed: tstamp:404619949759 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12940.181207: rtos_queue_send_failed: tstamp:404619950324 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.181218: rtos_queue_send_from_isr_failed: tstamp:404619959451 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.181227: rtos_queue_send_from_isr_failed: tstamp:404619959558 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12940.181234: rtos_queue_send_from_isr_failed: tstamp:404619959664 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12940.181241: rtos_queue_send_from_isr_failed: tstamp:404619959772 queue:0x0b4af718
kworker/2:0-10172 [002] … 12940.181248: rtos_queue_send_from_isr_failed: tstamp:404619959877 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12940.181256: rtos_queue_send_from_isr_failed: tstamp:404619959982 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12940.181263: rtos_queue_send_from_isr_failed: tstamp:404619960087 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12940.181271: rtos_queue_send_failed: tstamp:404619960508 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.181278: rtos_queue_send_from_isr_failed: tstamp:404619971259 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.181285: rtos_queue_send_from_isr_failed: tstamp:404619971365 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12940.181293: rtos_queue_send_from_isr_failed: tstamp:404619971472 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12940.181300: rtos_queue_send_from_isr_failed: tstamp:404619971581 queue:0x0b4af718
kworker/2:0-10172 [002] … 12940.181307: rtos_queue_send_from_isr_failed: tstamp:404619971684 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12940.181318: rtos_queue_send_from_isr_failed: tstamp:404619971788 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12940.181328: rtos_queue_send_from_isr_failed: tstamp:404619971893 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12940.181336: rtos_queue_send_failed: tstamp:404619972337 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.181344: rtos_queue_send_from_isr_failed: tstamp:404619976765 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.181352: rtos_queue_send_from_isr_failed: tstamp:404619976874 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12940.181365: rtos_queue_send_from_isr_failed: tstamp:404619976988 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12940.181373: rtos_queue_send_from_isr_failed: tstamp:404619977096 queue:0x0b4af718
kworker/2:0-10172 [002] … 12940.181381: rtos_queue_send_from_isr_failed: tstamp:404619977202 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12940.181388: rtos_queue_send_from_isr_failed: tstamp:404619977307 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12940.181395: rtos_queue_send_from_isr_failed: tstamp:404619977412 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12940.181403: rtos_queue_send_failed: tstamp:404619978579 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.181412: rtcpu_vinotify_event: tstamp:404619979445 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:404619978281 data:0x00010000
kworker/2:0-10172 [002] … 12940.181421: rtos_queue_peek_from_isr_failed: tstamp:404619997766 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12940.236958: rtcpu_vinotify_event: tstamp:404620371221 tag:CHANSEL_PXL_SOF channel:0x00 frame:33946 vi_tstamp:404620370473 data:0x00000001
kworker/2:0-10172 [002] … 12940.237022: rtcpu_vinotify_event: tstamp:404620371392 tag:ATOMP_FS channel:0x00 frame:33946 vi_tstamp:404620370481 data:0x00000000
kworker/2:0-10172 [002] … 12940.237030: rtcpu_vinotify_event: tstamp:404620371509 tag:CHANSEL_FAULT channel:0x00 frame:33946 vi_tstamp:404620370790 data:0x00000200
kworker/2:0-10172 [002] … 12940.237038: rtcpu_vinotify_event: tstamp:404620372378 tag:CHANSEL_LOAD_FRAMED channel:0x10 frame:33946 vi_tstamp:404620371649 data:0x08000000
kworker/2:0-10172 [002] … 12940.237046: rtcpu_vinotify_event: tstamp:404620372488 tag:CHANSEL_FAULT_FE channel:0x10 frame:33946 vi_tstamp:404620371650 data:0x00000001
kworker/2:0-10172 [002] … 12940.237068: rtcpu_vinotify_event: tstamp:404620372631 tag:ATOMP_FE channel:0x00 frame:33946 vi_tstamp:404620371653 data:0x00000000
kworker/2:0-10172 [002] … 12940.237081: rtos_queue_send_from_isr_failed: tstamp:404621089126 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.237092: rtos_queue_send_from_isr_failed: tstamp:404621089239 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12940.237201: rtos_queue_send_from_isr_failed: tstamp:404621089350 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12940.237210: rtos_queue_send_from_isr_failed: tstamp:404621089458 queue:0x0b4af718
kworker/2:0-10172 [002] … 12940.237218: rtos_queue_send_from_isr_failed: tstamp:404621089563 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12940.237226: rtos_queue_send_from_isr_failed: tstamp:404621089668 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12940.237237: rtos_queue_send_from_isr_failed: tstamp:404621089772 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12940.237248: rtos_queue_send_failed: tstamp:404621090333 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.348959: rtos_queue_peek_from_isr_failed: tstamp:404624997765 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12940.410478: rtos_queue_send_from_isr_failed: tstamp:404627195100 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.410505: rtos_queue_send_from_isr_failed: tstamp:404627195210 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12940.410507: rtos_queue_send_from_isr_failed: tstamp:404627195317 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12940.410509: rtos_queue_send_from_isr_failed: tstamp:404627195424 queue:0x0b4af718
kworker/2:0-10172 [002] … 12940.410511: rtos_queue_send_from_isr_failed: tstamp:404627195531 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12940.410513: rtos_queue_send_from_isr_failed: tstamp:404627195634 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12940.410520: rtos_queue_send_from_isr_failed: tstamp:404627195739 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12940.410557: rtos_queue_send_failed: tstamp:404627196180 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.465136: rtos_queue_send_from_isr_failed: tstamp:404627724538 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.465202: rtos_queue_send_from_isr_failed: tstamp:404627724649 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12940.465207: rtos_queue_send_from_isr_failed: tstamp:404627724755 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12940.465210: rtos_queue_send_from_isr_failed: tstamp:404627724864 queue:0x0b4af718
kworker/2:0-10172 [002] … 12940.465214: rtos_queue_send_from_isr_failed: tstamp:404627724969 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12940.465218: rtos_queue_send_from_isr_failed: tstamp:404627725073 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12940.465222: rtos_queue_send_from_isr_failed: tstamp:404627725178 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12940.465236: rtos_queue_send_failed: tstamp:404627725635 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.465306: rtos_queue_send_from_isr_failed: tstamp:404627730539 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.465310: rtos_queue_send_from_isr_failed: tstamp:404627730646 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12940.465316: rtos_queue_send_from_isr_failed: tstamp:404627730751 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12940.465321: rtos_queue_send_from_isr_failed: tstamp:404627730860 queue:0x0b4af718
kworker/2:0-10172 [002] … 12940.465325: rtos_queue_send_from_isr_failed: tstamp:404627730965 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12940.465329: rtos_queue_send_from_isr_failed: tstamp:404627731070 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12940.465333: rtos_queue_send_from_isr_failed: tstamp:404627731175 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12940.465339: rtos_queue_send_failed: tstamp:404627732085 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.465344: rtos_queue_send_from_isr_failed: tstamp:404627738933 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.465348: rtos_queue_send_from_isr_failed: tstamp:404627739042 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12940.465352: rtos_queue_send_from_isr_failed: tstamp:404627739148 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12940.465356: rtos_queue_send_from_isr_failed: tstamp:404627739257 queue:0x0b4af718
kworker/2:0-10172 [002] … 12940.465360: rtos_queue_send_from_isr_failed: tstamp:404627739362 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12940.465364: rtos_queue_send_from_isr_failed: tstamp:404627739466 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12940.465368: rtos_queue_send_from_isr_failed: tstamp:404627739571 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12940.465371: rtos_queue_send_failed: tstamp:404627740127 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.465375: rtos_queue_send_from_isr_failed: tstamp:404627745280 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.465379: rtos_queue_send_from_isr_failed: tstamp:404627745387 queue:0x0b4ab1a8
kworker/2:0-10172 [002] … 12940.465383: rtos_queue_send_from_isr_failed: tstamp:404627745493 queue:0x0b4acdd8
kworker/2:0-10172 [002] … 12940.465387: rtos_queue_send_from_isr_failed: tstamp:404627745599 queue:0x0b4af718
kworker/2:0-10172 [002] … 12940.465391: rtos_queue_send_from_isr_failed: tstamp:404627745704 queue:0x0b4b04d8
kworker/2:0-10172 [002] … 12940.465395: rtos_queue_send_from_isr_failed: tstamp:404627745809 queue:0x0b4b1298
kworker/2:0-10172 [002] … 12940.465399: rtos_queue_send_from_isr_failed: tstamp:404627745914 queue:0x0b4b2058
kworker/2:0-10172 [002] … 12940.465402: rtos_queue_send_failed: tstamp:404627746340 queue:0x0b4a7698
kworker/2:0-10172 [002] … 12940.520955: rtos_queue_peek_from_isr_failed: tstamp:404629997759 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12940.688923: rtos_queue_peek_from_isr_failed: tstamp:404634997757 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12940.856946: rtos_queue_peek_from_isr_failed: tstamp:404639997741 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12941.024956: rtos_queue_peek_from_isr_failed: tstamp:404644997737 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12941.136954: rtos_queue_peek_from_isr_failed: tstamp:404649997730 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12941.304955: rtos_queue_peek_from_isr_failed: tstamp:404654997724 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12941.472959: rtos_queue_peek_from_isr_failed: tstamp:404659997714 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12941.641003: rtos_queue_peek_from_isr_failed: tstamp:404664997708 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12941.809038: rtos_queue_peek_from_isr_failed: tstamp:404669997702 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12941.976973: rtos_queue_peek_from_isr_failed: tstamp:404674997696 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12942.145008: rtos_queue_peek_from_isr_failed: tstamp:404679997690 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12942.256937: rtos_queue_peek_from_isr_failed: tstamp:404684997680 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12942.424963: rtos_queue_peek_from_isr_failed: tstamp:404689997673 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12942.593010: rtos_queue_peek_from_isr_failed: tstamp:404694997667 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12942.760967: rtos_queue_peek_from_isr_failed: tstamp:404699997660 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12942.928970: rtos_queue_peek_from_isr_failed: tstamp:404704997654 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12943.096964: rtos_queue_peek_from_isr_failed: tstamp:404709997649 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12943.265000: rtos_queue_peek_from_isr_failed: tstamp:404714997642 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12943.376980: rtos_queue_peek_from_isr_failed: tstamp:404719997633 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12943.544983: rtos_queue_peek_from_isr_failed: tstamp:404724997627 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12943.712976: rtos_queue_peek_from_isr_failed: tstamp:404729997621 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12943.880992: rtos_queue_peek_from_isr_failed: tstamp:404734997615 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12944.049017: rtos_queue_peek_from_isr_failed: tstamp:404739997608 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12944.217002: rtos_queue_peek_from_isr_failed: tstamp:404744997601 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12944.384995: rtos_queue_peek_from_isr_failed: tstamp:404749997595 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12944.496981: rtos_queue_peek_from_isr_failed: tstamp:404754997588 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12944.665065: rtos_queue_peek_from_isr_failed: tstamp:404759997580 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12944.832967: rtos_queue_peek_from_isr_failed: tstamp:404764997573 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12945.000968: rtos_queue_peek_from_isr_failed: tstamp:404769997566 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12945.168973: rtos_queue_peek_from_isr_failed: tstamp:404774997565 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12945.336981: rtos_queue_peek_from_isr_failed: tstamp:404779997555 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12945.504983: rtos_queue_peek_from_isr_failed: tstamp:404784997545 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12945.616999: rtos_queue_peek_from_isr_failed: tstamp:404789997538 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12945.784983: rtos_queue_peek_from_isr_failed: tstamp:404794997533 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12945.953015: rtos_queue_peek_from_isr_failed: tstamp:404799997526 queue:0x0b4b4940
kworker/2:0-10172 [002] … 12946.121015: rtos_queue_peek_from_isr_failed: tstamp:404804409164 queue:0x0b4b4940
$ v4l2-ctl --list-formats-ext -d /dev/video0
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘UYVY’
Size: Discrete 1920x1080
Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 3840x2160
Size: Discrete 1280x1024
    Index       : 1
    Pixel Format: 'NV16'
    Index       : 2
    Pixel Format: 'UYVY'
The CHANSEL_FAULT tell PIXEL_SHORT_LINE, that tell the output size doesn’t as expected.
https://elinux.org/Jetson/l4t/Camera_BringUp#Steps_to_enable_more_debug_messages
Hello ShaneCCC,
Thank you for your reply. I will try the debugging method in your reply.
But there may be no results recently, I’m working on other things.
I’ll update this post later.
Hi ShaneCCC,
Thank you! Found the reason, I shouldn’t set ‘use_sensor_mode_id’ to ‘true’ in the device tree.
