I’m using RHEL 6.3 (2.6.32-279.el6.x86_64)
Video Card: NVIDIA Quadro 410
Installed Graphic Driver: NVIDIA-Linux-x86_64-331.79
I’m trying to run Xserver, but it won’t start.
Here is a log file:
cat /var/log/Xorg.0.log
[ 641.698]
X.Org X Server 1.10.6
Release Date: 2012-02-10
[ 641.699] X Protocol Version 11, Revision 0
[ 641.699] Build Operating System: x86-007 2.6.18-308.1.1.el5
[ 641.699] Current Operating System: Linux mos120.cadence.com 2.6.32-279.el6.x86_64 #1 SMP Wed Jun 13 18:24:36 EDT 2012 x86_64
[ 641.700] Kernel command line: ro root=UUID=af5b1128-71a2-4831-8b80-30c1fe45bcb8 intel_iommu=on rd_NO_LUKS rd_LVM_LV=vg00/lswap LANG=en_US.UTF-8 rd_NO_MD SYSFONT=latarcyrheb-sun16 crashkernel=130M@0M KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM
[ 641.701] Build Date: 28 March 2012 03:02:14PM
[ 641.701] Build ID: xorg-x11-server 1.10.6-1.el6
[ 641.702] Current version of pixman: 0.18.4
[ 641.702] Before reporting problems, check https://www.redhat.com/apps/support/
to make sure that you have the latest version.
[ 641.703] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 641.704] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jun 17 13:45:26 2014
[ 641.707] (==) Using config file: "/etc/X11/xorg.conf"
[ 641.708] (==) ServerLayout "X.org Configured"
[ 641.708] (**) |-->Screen "Screen0" (0)
[ 641.708] (**) | |-->Monitor "Monitor0"
[ 641.708] (**) | |-->Device "Card0"
[ 641.708] (**) |-->Screen "Screen1" (1)
[ 641.708] (**) | |-->Monitor "Monitor1"
[ 641.708] (**) | |-->Device "Card1"
[ 641.708] (**) |-->Screen "Screen2" (2)
[ 641.708] (**) | |-->Monitor "Monitor2"
[ 641.708] (**) | |-->Device "Card2"
[ 641.708] (**) |-->Screen "Screen3" (3)
[ 641.708] (**) | |-->Monitor "Monitor3"
[ 641.708] (**) | |-->Device "Card3"
[ 641.708] (**) |-->Input Device "Mouse0"
[ 641.708] (**) |-->Input Device "Keyboard0"
[ 641.708] (==) Automatically adding devices
[ 641.708] (==) Automatically enabling devices
[ 641.708] (**) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins,
built-ins
[ 641.708] (**) ModulePath set to "/usr/lib64/xorg/modules"
[ 641.708] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 641.708] (WW) Disabling Mouse0
[ 641.708] (WW) Disabling Keyboard0
[ 641.708] (II) Loader magic: 0x7d6960
[ 641.708] (II) Module ABI versions:
[ 641.708] X.Org ANSI C Emulation: 0.4
[ 641.708] X.Org Video Driver: 10.0
[ 641.708] X.Org XInput driver : 12.2
[ 641.708] X.Org Server Extension : 5.0
[ 641.708] (--) PCI:*(0:5:0:0) 10de:0fff:103c:094a rev 161, Mem @ 0xee000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000c000/128, BIOS @ 0x????????/524288
[ 641.709] (II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
[ 641.709] (II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
[ 641.709] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[ 641.709] (II) "record" will be loaded. This was enabled by default and also specified in the config file.
[ 641.709] (II) "dri" will be loaded by default.
[ 641.709] (II) "dri2" will be loaded. This was enabled by default and also specified in the config file.
[ 641.709] (II) LoadModule: "dbe"
[ 641.714] (II) Loading /usr/lib64/xorg/modules/extensions/libdbe.so
[ 641.714] (II) Module dbe: vendor="X.Org Foundation"
[ 641.714] compiled for 1.10.6, module version = 1.0.0
[ 641.714] Module class: X.Org Server Extension
[ 641.714] ABI class: X.Org Server Extension, version 5.0
[ 641.714] (II) Loading extension DOUBLE-BUFFER
[ 641.714] (II) LoadModule: "extmod"
[ 641.714] (II) Loading /usr/lib64/xorg/modules/extensions/libextmod.so
[ 641.716] (II) Module extmod: vendor="X.Org Foundation"
[ 641.716] compiled for 1.10.6, module version = 1.0.0
[ 641.716] Module class: X.Org Server Extension
[ 641.716] ABI class: X.Org Server Extension, version 5.0
[ 641.716] (II) Loading extension SELinux
[ 641.716] (II) Loading extension MIT-SCREEN-SAVER
[ 641.716] (II) Loading extension XFree86-VidModeExtension
[ 641.716] (II) Loading extension XFree86-DGA
[ 641.716] (II) Loading extension DPMS
[ 641.716] (II) Loading extension XVideo
[ 641.716] (II) Loading extension XVideo-MotionCompensation
[ 641.716] (II) Loading extension X-Resource
[ 641.716] (II) LoadModule: "dri2"
[ 641.716] (II) Loading /usr/lib64/xorg/modules/extensions/libdri2.so
[ 641.717] (II) Module dri2: vendor="X.Org Foundation"
[ 641.717] compiled for 1.10.6, module version = 1.2.0
[ 641.717] ABI class: X.Org Server Extension, version 5.0
[ 641.717] (II) Loading extension DRI2
[ 641.717] (II) LoadModule: "record"
[ 641.717] (II) Loading /usr/lib64/xorg/modules/extensions/librecord.so
[ 641.718] (II) Module record: vendor="X.Org Foundation"
[ 641.718] compiled for 1.10.6, module version = 1.13.0
[ 641.718] Module class: X.Org Server Extension
[ 641.718] ABI class: X.Org Server Extension, version 5.0
[ 641.718] (II) Loading extension RECORD
[ 641.718] (II) LoadModule: "glx"
[ 641.723] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 641.819] (II) Module glx: vendor="NVIDIA Corporation"
[ 641.819] compiled for 4.0.2, module version = 1.0.0
[ 641.819] Module class: X.Org Server Extension
[ 641.819] (II) NVIDIA GLX Module 331.79 Sat May 17 23:58:32 PDT 2014
[ 641.820] (II) Loading extension GLX
[ 641.820] (II) LoadModule: "dri"
[ 641.820] (II) Loading /usr/lib64/xorg/modules/extensions/libdri.so
[ 641.821] (II) Module dri: vendor="X.Org Foundation"
[ 641.821] compiled for 1.10.6, module version = 1.0.0
[ 641.821] ABI class: X.Org Server Extension, version 5.0
[ 641.821] (II) Loading extension XFree86-DRI
[ 641.821] (II) LoadModule: "nvidia"
[ 641.821] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 641.828] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 641.829] compiled for 4.0.2, module version = 1.0.0
[ 641.829] Module class: X.Org Video Driver
[ 641.830] (II) NVIDIA dlloader X Driver 331.79 Sat May 17 23:37:42 PDT 2014
[ 641.830] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 641.830] (--) using VT number 7
[ 641.842] (II) Loading sub module "fb"
[ 641.842] (II) LoadModule: "fb"
[ 641.842] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 641.843] (II) Module fb: vendor="X.Org Foundation"
[ 641.843] compiled for 1.10.6, module version = 1.0.0
[ 641.843] ABI class: X.Org ANSI C Emulation, version 0.4
[ 641.843] (II) Loading sub module "wfb"
[ 641.843] (II) LoadModule: "wfb"
[ 641.843] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 641.845] (II) Module wfb: vendor="X.Org Foundation"
[ 641.845] compiled for 1.10.6, module version = 1.0.0
[ 641.845] ABI class: X.Org ANSI C Emulation, version 0.4
[ 641.845] (II) Loading sub module "ramdac"
[ 641.845] (II) LoadModule: "ramdac"
[ 641.845] (II) Module "ramdac" already built-in
[ 641.846] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 641.846] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 641.846] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 641.847] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 641.847] (==) NVIDIA(0): RGB weight 888
[ 641.847] (==) NVIDIA(0): Default visual is TrueColor
[ 641.847] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 641.847] (**) NVIDIA(0): Enabling 2D acceleration
[ 642.374] (II) NVIDIA(0): NVIDIA GPU Quadro 410 (GK107GL) at PCI:5:0:0 (GPU-0)
[ 642.374] (--) NVIDIA(0): Memory: 524288 kBytes
[ 642.374] (--) NVIDIA(0): VideoBIOS: 80.07.47.00.17
[ 642.374] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 642.378] (--) NVIDIA(0): Valid display device(s) on Quadro 410 at PCI:5:0:0
[ 642.378] (--) NVIDIA(0): CRT-0
[ 642.378] (--) NVIDIA(0): DFP-0 (boot)
[ 642.378] (--) NVIDIA(0): DFP-1
[ 642.378] (--) NVIDIA(0): DFP-2
[ 642.378] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 642.378] (--) NVIDIA(0): DFP-0: Internal Single Link TMDS
[ 642.378] (--) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 642.378] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
[ 642.378] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 642.378] (--) NVIDIA(0): DFP-2: Internal DisplayPort
[ 642.378] (--) NVIDIA(0): DFP-2: 960.0 MHz maximum pixel clock
[ 642.378] (EE) NVIDIA(0): Failed to assign any connected display devices to X screen 0.
[ 642.378] (EE) NVIDIA(0): Set AllowEmptyInitialConfiguration if you want the server
[ 642.378] (EE) NVIDIA(0): to start anyway
[ 642.596] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 642.596] (II) UnloadModule: "nvidia"
[ 642.596] (II) Unloading nvidia
[ 642.596] (II) UnloadModule: "wfb"
[ 642.596] (II) Unloading wfb
[ 642.596] (II) UnloadModule: "fb"
[ 642.596] (II) Unloading fb
[ 642.596] (EE) Screen(s) found, but none have a usable configuration.
[ 642.596]
Fatal server error:
[ 642.596] no screens found
[ 642.596]
Please consult the Red Hat, Inc. support
at https://www.redhat.com/apps/support/
for help.
[ 642.596] Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 642.596]
Here is xorg.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 331.79 (buildmeister@swio-display-x86-rhel47-09) Sun May 18 00:42:05 PDT 2014
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" RightOf "Screen0"
Screen 2 "Screen2" RightOf "Screen1"
Screen 3 "Screen3" RightOf "Screen2"
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
Option "AllowEmptyInput" "no"
EndSection
Section "Files"
ModulePath "/usr/lib64/xorg/modules"
FontPath "catalogue:/etc/X11/fontpath.d"
FontPath "built-ins"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "dri2"
Load "record"
Load "glx"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Monitor"
Identifier "Monitor1"
EndSection
Section "Monitor"
Identifier "Monitor2"
EndSection
Section "Monitor"
Identifier "Monitor3"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
### <percent>: "<f>%"
### [arg]: arg optional
#Option "SWcursor" # [<bool>]
#Option "HWcursor" # [<bool>]
#Option "NoAccel" # [<bool>]
#Option "ShadowFB" # [<bool>]
#Option "UseFBDev" # [<bool>]
#Option "Rotate" # [<str>]
#Option "VideoKey" # <i>
#Option "FlatPanel" # [<bool>]
#Option "FPDither" # [<bool>]
#Option "CrtcNumber" # <i>
#Option "FPScale" # [<bool>]
#Option "FPTweak" # <i>
#Option "DualHead" # [<bool>]
Identifier "Card0"
Driver "nvidia"
BusID "PCI:5:0:0"
EndSection
Section "Device"
Identifier "Card1"
Driver "nvidia"
BusID "PCI:5:0:0"
EndSection
Section "Device"
#Option "Rotate" # <str>
#Option "fbdev" # <str>
#Option "debug" # [<bool>]
Identifier "Card2"
Driver "nvidia"
BusID "PCI:5:0:0"
EndSection
Section "Device"
#Option "DefaultRefresh" # [<bool>]
#Option "ModeSetClearScreen" # [<bool>]
Identifier "Card3"
Driver "nvidia"
BusID "PCI:5:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Card1"
Monitor "Monitor1"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen2"
Device "Card2"
Monitor "Monitor2"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen3"
Device "Card3"
Monitor "Monitor3"
Viewport 0 0
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
I’m stuck, please help.
UPD. Also
$ lspci -nn | grep VGA
05:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:0fff] (rev a1)
nvidia-bug-report.log.gz (193 KB)
