Hi ,
Now my sensor outputs data via MIPI CPHY. How can I configure the Xavier device tree to receive data from CPHY? I want to use this trios.
Check the programing guide to implement the sensor driver and configure the phy_mode = “CPHY” for it.
Do you typo?
Only need modify the phy_mode.
Get the trace log to check the PHY mode.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 3 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
Run the camera capturing and run “sudo cat /sys/kernel/debug/tracing/trace” again.
Hi ShaneCCC,
Below is the log.Please help analyze the log.
How do I know if I’m working in cphy mode or dphy mode
log.txt (18.6 KB)
Looks like the trace log didn’t show the message.
Could you print the configure in csi5_fops.c
No, this is use to configurate NVCSI instead of sensor.
You should able see the change in csi5_fops.c when phy_mode change in your dts.
Confirm the return from the read_phy_mode_from_dt() in csi5_fops.c
static int csi5_stream_set_config(struct tegra_csi_channel *chan, u32 stream_id,
u32 csi_port, int csi_lanes)
struct tegra_csi_device *csi = chan->csi;
struct tegra_channel *tegra_chan =
v4l2_get_subdev_hostdata(&chan->subdev);
struct camera_common_data *s_data = chan->s_data;
const struct sensor_mode_properties *mode = NULL;
unsigned int cil_settletime = 0;
unsigned int lane_polarity = 0;
unsigned int index = 0;
int vi_port = 0;
struct CAPTURE_CONTROL_MSG msg;
struct nvcsi_brick_config brick_config;
struct nvcsi_cil_config cil_config;
u32 phy_mode = read_phy_mode_from_dt(chan);
bool is_cphy = (phy_mode == CSI_PHY_MODE_CPHY);
dev_dbg(csi->dev, "%s: stream_id=%u, csi_port=%u\n",
__func__, stream_id, csi_port);
Hi ShaneCCC,
Now I can not change the image .Do you have another way to debug this problem?
I check the dts ,I do change phy_mode to cphy and I check the /proc/device-tree.But mipi still work in dphy mode.
That’s weird!!
Have below debug RCE firmware to check the PHY mode in RTCPU side.
