Xavier developer kit through the SDK flash the system,two type-C usb interface cannot use,The display information is ”ucsi_ccg 1008:port evt Type-C Error Recovery”
cutecom.log (95.2 KB)
Are you sure you are flashing the pure driver package from SDKManager? I saw you have other topics that are talking about xavier case before. Did you see similar case at that time?
This developer kit belongs to one of our customers, and I confirmed to him that it was flash with SDK. I checked the DTS file through the debugging port, and it was for the developer kit. I haven’t meet this problem before.
Does customer have other developer kit that can validate the software? If only one board has this issue, then need to RMA.
Ok, Thank you very much.
