Xavier Nx fails to boot after running rootOnNVMe script
Hello! I’m having issues getting my Xavier nx to boot after running rootOnNVMe: GitHub - jetsonhacks/rootOnNVMe: Switch the rootfs to a NVMe SSD on the Jetson Xavier NX and Jetson AGX Xavier I’m getting no output on the screen at all. I was able to get a log from the serial which I"ll attach. But I’m also not able to get into recovery. In order to flash the first time I had to use: reboot force-recovery to get it in recovery mode.
Any thoughts? Thanks!
xavier-nx-log.txt (12.4 KB)
Recovery mode is pure hardware triggered event. It has nothing to do with anything previous installed on your board.
What I saw is just a log that got boot failure. It didn’t indicate anything with recovery mode or flash failure.
You should use pin on J14 to put the board into recovery mode if you cannot use command to make it happened.
