I tried to use I2C buses from the SOM (I2C0, I2C1, I2C2 and CAM I2C) from user space. I figured out from “i2cdetect” that CAM I2C maps to “/dev/i2c-2”. What is mapping of I2C0, I2C1 and I2C2 from SOM to “/dev/i2c-x”?
Thanks in advance.
Have reference to below topic for bus and pin relationship.
Thanks for the response. I downloaded Xiver NX Pinmux table but could not find base address of I2C buses from the Pinmux table.
I still can’t find mapping between the I2Cs from SOM to “/dev/i2c-x”.
Have a check to this.
I2C addresses
| Bus I2C | Label Device Tree |
| i2c0 | 3160000 I2C1_CLK/I2C1_DAT |
| i2c1 | c240000 I2C2_CLK/I2C2_DAT |
| i2c2 | 3180000 I2C3_CLK/I2C3_DAT |
| i2c3 | 3190000 DP_AUX_CH1_* |
| i2c4 | 31a0000 N/A |
| i2c5 | 31b0000 DP_AUX_CH0_* |
| i2c6 | 31c0000 DP_AUX_CH2_* |
| i2c7 | c250000 2C4_CLK/I2C4_DAT |
| i2c8 | 31e0000 2C5_CLK/I2C5_DAT |
Thanks again. I will need the mapping from the I2C0, I2C1 and I2C2 of the Xavier NX SOM to the “Bus I2C”.
For example, the table above only specifies “i2c2 3180000 I2C3_CLK/I2C3_DAT” but it does not relate “i2c2” to “CAM I2C” on the Xavier NX SOM. What I need is mapping:
SOM I2C => Bus I2C
I2C0 => ?
I2C1 => ?
I2C2 => ?
CAM I2C => 2
I found more information from Device Tree:
cam_i2c = “i2c@3180000”
hdr40_i2c0 = “i2c@c240000”
hdr40_i2c1 = “i2c@31e0000”
It seems SOM I2C0 is mapped to Bus I2C-1, SOM I2C1 is mapped to Bus I2C-8
