Greetings,
I’m working with an embedded build of the rdma-core code (and rdma-perftest but I’m not that far yet). We’re doing a cross build of the rdma-core code using yocto targeted at an Altera Arria10 board which includes a dual-core ARM Cortex-A9 processor. I’ve been able to successfully build the kernel 4.15 with the rxe modules. However, when I build the userland and get to the rdma-core library I run into a number of issues. One has been particularly vexing. During the do_configure() stage of the yocto build for rdma-core, I get errors regarding the installation of the rdma_man_pages. In particular, in the buildlib/rdma_man.cmake file, there is a routine: function(rdma_man_pages) that fails. If I comment out the entire body of this function, I can get the binaries to build but that takes me to another problem during the do_install portion. It appears that pandoc is not available at this stage. I suppose I can try to add pandoc with a separate recipe and then try again. Anyone have any comments on this build issue?
Thanks,
FM
