here is the dmsg log:
[ 440.645833] NOHZ: local_softirq_pending 80
[ 441.073823] NOHZ: local_softirq_pending 80
[ 441.352947] ixgbe 0000:03:00.0 enp3s0: Received unrecoverable ECC Err,initiating reset.
[ 441.357872] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 441.368547] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 441.374803] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 441.384298] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 441.393814] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 441.403348] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 441.412834] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 447.277819] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 448.210210] ixgbe 0000:03:00.0 enp3s0: Detected Tx Unit Hang
Tx Queue <2>
TDH, TDT <0>, <3>
next_to_use <3>
next_to_clean <0>
[ 448.210214] ixgbe 0000:03:00.0 enp3s0: Detected Tx Unit Hang
Tx Queue <3>
TDH, TDT <0>, <4>
next_to_use <4>
next_to_clean <0>
[ 448.210222] ixgbe 0000:03:00.0 enp3s0: tx_buffer_info[next_to_clean]
time_stamp <100008fd6>
jiffies <1000090bc>
[ 448.210225] ixgbe 0000:03:00.0 enp3s0: Detected Tx Unit Hang
Tx Queue <0>
TDH, TDT <0>, <5>
next_to_use <5>
next_to_clean <0>
[ 448.210227] ixgbe 0000:03:00.0 enp3s0: tx hang 2 detected on queue 3, resetting adapter
[ 448.210229] ixgbe 0000:03:00.0 enp3s0: tx_buffer_info[next_to_clean]
time_stamp <100008fd3>
jiffies <1000090bc>
[ 448.210232] ixgbe 0000:03:00.0 enp3s0: tx hang 2 detected on queue 0, resetting adapter
[ 448.210244] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 448.216427] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 448.216576] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 448.216702] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 448.216819] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 448.216948] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 448.217073] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 448.362440] ixgbe 0000:03:00.0 enp3s0: tx_buffer_info[next_to_clean]
time_stamp <100009080>
jiffies <1000090e2>
[ 448.377755] ixgbe 0000:03:00.0 enp3s0: tx hang 3 detected on queue 2, resetting adapter
[ 454.203769] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 455.048774] ixgbe 0000:03:00.0 enp3s0: Detected Tx Unit Hang
Tx Queue <0>
TDH, TDT <0>, <5>
next_to_use <5>
next_to_clean <0>
[ 455.066577] ixgbe 0000:03:00.0 enp3s0: tx_buffer_info[next_to_clean]
time_stamp <100009696>
jiffies <10000976e>
[ 455.081726] ixgbe 0000:03:00.0 enp3s0: tx hang 3 detected on queue 0, resetting adapter
[ 455.081743] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 455.092949] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 455.099208] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 455.108699] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 455.118275] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 455.127677] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 455.137251] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 460.932291] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 461.938211] ixgbe 0000:03:00.0 enp3s0: Detected Tx Unit Hang
Tx Queue <0>
TDH, TDT <0>, <5>
next_to_use <5>
next_to_clean <0>
[ 461.938249] ixgbe 0000:03:00.0 enp3s0: Detected Tx Unit Hang
Tx Queue <3>
TDH, TDT <0>, <1>
next_to_use <1>
next_to_clean <0>
[ 461.938255] ixgbe 0000:03:00.0 enp3s0: Detected Tx Unit Hang
Tx Queue <4>
TDH, TDT <0>, <2>
next_to_use <2>
next_to_clean <0>
[ 461.938261] ixgbe 0000:03:00.0 enp3s0: tx_buffer_info[next_to_clean]
time_stamp <100009d2d>
jiffies <100009e24>
[ 461.938271] ixgbe 0000:03:00.0 enp3s0: tx_buffer_info[next_to_clean]
time_stamp <100009d94>
jiffies <100009e24>
[ 461.938274] ixgbe 0000:03:00.0 enp3s0: tx hang 4 detected on queue 3, resetting adapter
[ 461.938280] ixgbe 0000:03:00.0 enp3s0: tx hang 4 detected on queue 4, resetting adapter
[ 461.938307] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 461.944485] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 461.944610] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 461.944735] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 461.944861] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 461.944981] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 461.945106] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 462.090435] ixgbe 0000:03:00.0 enp3s0: tx_buffer_info[next_to_clean]
time_stamp <100009d28>
jiffies <100009e4a>
[ 462.105754] ixgbe 0000:03:00.0 enp3s0: tx hang 5 detected on queue 0, resetting adapter
[ 467.665817] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 467.781968] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 467.782231] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 468.769783] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 468.776824] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 468.783077] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 468.792569] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 468.802057] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 468.811553] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 468.821031] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 474.407560] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 474.526228] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 474.526494] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 475.489776] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 475.497565] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 475.503818] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 475.513307] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 475.522796] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 475.532285] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 475.542975] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 481.190251] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 481.305714] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 481.306018] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 482.209782] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 482.243971] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 482.250235] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 482.259718] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 482.269206] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 482.278695] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 482.288265] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 487.867890] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 487.984538] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 487.984801] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 488.961776] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 494.748936] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 494.869723] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 494.870024] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 495.649792] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 501.230376] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 501.347230] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 501.347493] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 502.337783] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 502.343840] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 502.350088] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 502.359581] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 502.369068] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 502.378558] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 502.388044] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 508.042855] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 509.202127] ixgbe 0000:03:00.0 enp3s0: Detected Tx Unit Hang
Tx Queue <0>
TDH, TDT <0>, <6>
next_to_use <6>
next_to_clean <0>
[ 509.202140] ixgbe 0000:03:00.0 enp3s0: Detected Tx Unit Hang
Tx Queue <3>
TDH, TDT <0>, <3>
next_to_use <3>
next_to_clean <0>
[ 509.202153] ixgbe 0000:03:00.0 enp3s0: tx_buffer_info[next_to_clean]
time_stamp <10000cb2a>
jiffies <10000cc4c>
[ 509.202158] ixgbe 0000:03:00.0 enp3s0: tx hang 11 detected on queue 3, resetting adapter
[ 509.202184] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 509.208358] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 509.208476] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 509.208593] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 509.208711] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 509.208829] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 509.208947] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 509.318145] ixgbe 0000:03:00.0 enp3s0: tx_buffer_info[next_to_clean]
time_stamp <10000cb2d>
jiffies <10000cc69>
[ 509.333296] ixgbe 0000:03:00.0 enp3s0: tx hang 12 detected on queue 0, resetting adapter
[ 515.173875] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 515.293773] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 515.294036] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 516.001781] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 521.783521] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 521.902115] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 521.902379] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 522.689777] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 522.697571] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 522.703902] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 522.713389] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 522.722878] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 522.732370] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 522.741881] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 528.595255] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 528.711801] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 528.712065] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 529.441792] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 529.449588] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 529.455925] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 529.465414] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 529.474912] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 529.484401] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 529.494091] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 535.502990] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 535.622142] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 535.622405] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 536.193785] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 541.990710] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 542.109711] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 542.110005] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 542.881779] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 548.549815] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 548.667745] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 548.668007] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 549.569782] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 555.378137] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 556.361791] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 556.362056] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 556.465784] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 562.052750] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 562.171356] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 562.171620] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
[ 563.137787] ixgbe 0000:03:00.0 enp3s0: Reset adapter
[ 563.145576] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 563.151839] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 563.161317] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 563.170808] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 563.180373] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 4 not cleared within the polling period
[ 563.189885] ixgbe 0000:03:00.0 enp3s0: RXDCTL.ENABLE on Rx queue 5 not cleared within the polling period
[ 568.773422] ixgbe 0000:03:00.0 enp3s0: NIC Link is Up 10 Gbps, Flow Control: None
[ 568.890444] ixgbe 0000:03:00.0 enp3s0: NIC Link is Down
[ 568.890707] ixgbe 0000:03:00.0 enp3s0: initiating reset due to lost link with pending Tx work
