Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
I tried a do-release-upgrade on the Xavier drive kit to try to update to 20.04 LTS. The update finished perfectly but after the mandatory reboot there is no longer a video signal on any of the HDMI ports. I suspect the Nvidia video drivers to be the issue here. Trying to start the virtual terminal using ctrl+alt+F is also not working. Does anybody have an idea how we could try to get the video working after an update?
Dear @lucas.vandijck ,
We have not tested the upgrade. Could you please connect to target via minicom /dev/ttyUSB2 and check boot logs to see suspicious messages?
Excuse me, I would get back to you but I tried to flash the drive kit to return to version 18 LTS, but the flashing process is stuck at 99% progress.
VickNV
August 4, 2021, 4:52pm
4
Hi @lucas.vandijck ,
Please create another topic for the issue of stuck at 99% progress. Thanks.
VickNV
August 4, 2021, 4:53pm
5
Ubuntu 20.04 support isn’t available yet. I would suggest you to stick with 18.04 until then. Thanks.
These were the lines I found referencing the display in “journalctl -b”:
Log
sole [ttyS0] enabled
o tegra-gpio wake60 for gpio=96(M:0)
radc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor1
eric_infoframe_type: 0x87
radc 15210000.nvdisplay: DT parsed successfully
radc 15210000.nvdisplay: Display dc.ffffff800c810000 registered with id=1
radc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
radc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
radc 15210000.nvdisplay: hdmi: board prod-setting covers partial!
radc 15210000.nvdisplay: probed
tconsole [uart8250] disabled
radc 15210000.nvdisplay: fb registered
o tegra-gpio wake63 for gpio=97(M:1)
radc 15220000.nvdisplay: disp2 connected to head2->/host1x/sor2
radc 15220000.nvdisplay: DT parsed successfully
radc 15220000.nvdisplay: Display dc.ffffff800ca10000 registered with id=2
radc 15220000.nvdisplay: vblank syncpt # 13 for dc 2
radc 15220000.nvdisplay: vpulse3 syncpt # 14 for dc 2
radc 15220000.nvdisplay: hdmi: board prod-setting covers partial!
radc 15220000.nvdisplay: probed
con-disp-state external-connection:disp-state: cable 40 state 1
con HDMI: HPD enabled
radc 15200000.nvdisplay: hdmi: plugged
mu: Adding device 3110000.serial to group 1
0000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 94, base_baud = 0) is a TEGRA_UART
radc 15220000.nvdisplay: fb registered
o tegra-gpio wake71 for gpio=98(M:2)
radc 15230000.nvdisplay: disp3 connected to head3->/host1x/sor3
radc 15230000.nvdisplay: DT parsed successfully
radc 15230000.nvdisplay: Display dc.ffffff800cbd0000 registered with id=3
radc 15230000.nvdisplay: vblank syncpt # 15 for dc 3
radc 15230000.nvdisplay: vpulse3 syncpt # 16 for dc 3
radc 15230000.nvdisplay: hdmi: board prod-setting covers partial!
ra_hv_vblk tegra_virt_storage0: allocate drvdata buffer
radc 15230000.nvdisplay: probed
radc 15230000.nvdisplay: fb registered
k: send_config wait for ivc channel reset
o tegra-gpio wake66 for gpio=99(M:3)
ra_hv_vblk tegra_virt_storage0: send config cmd to ivc #127
ra_hv_vblk tegra_virt_storage1: allocate drvdata buffer
ra_hv_vblk tegra_virt_storage0: get config data from ivc #127
mary GPT is invalid, using alternate GPT.
lkdev0: p1
ra_hv_vblk tegra_virt_storage1: send config cmd to ivc #237
ra_hv_vblk tegra_virt_storage1: get config data from ivc #237
ra_hv_vblk tegra_virt_storage2: allocate drvdata buffer
