[378.09 Ubuntu 16.10 x64] Buggy windows shadows, controls and wallpaper after standby mode
Version: 378.09
OS: Ubuntu 16.10 x64
When my PC woke up from stand by mode i always have this:
http://joxi.ru/V2VaWbwCxd1aNm?d=1
Same here, suspend and return and same issue!http://i.imgur.com/jqHsQfe.jpg
Adicioning “nomodeset” on grub but no efect…
ubuntu 16.04
root@H97N-Wifi:/home/platao# uname -a
Linux H97N-Wifi 4.4.0-62-lowlatency #83-Ubuntu SMP PREEMPT Wed Jan 18 15:00:41 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
GTX 750Ti gigabyte H97N wifi
At least your wallpaper isn’t broken… My wallpaper looks like shadow on windows corner.
Issue still exists. Is there any plans to fix it?
No…maybe in the next release.
This issue is present in 375 and 378 drivers…
Here is a “workarround” to fix this, and wait to nvidia devs fix this problem ;(
Work for me!
https://bugs.launchpad.net/ubuntu/+source/nvidia-graphics-drivers-375/+bug/1667158
@experimancer Thank you for sharing.
Given that simply killing compiz process fixes the bad border problem, I have tested a solution that works on my Ubuntu 16.04 system every time after the system wakes. 2 steps solution. Hope it can help others.
Step 1:
I created a script called “fixbadborders” in the directory /lib/systemd/system-sleep.
It contained the following:
#!/bin/sh
This file (or a link to it) must be in the folder /lib/systemd/system-sleep/
Purpose: Kill compiz after system wakes up from sleep.
This will fix bad window borders caused by Nvidia driver 375.39.
kill $(ps -C compiz -o pid=)
Step 2:
Allowed the script to have executable permission with:
sudo chmod +x fixbadborders
This “workaround” does not work well for me. I get a lot of stutters after applying this.
When will nvidia devs fix this? I f*cking bored with this bug.
Lastest beta says it might got fixed:
https://devtalk.nvidia.com/default/topic/1002788
Can you test it to confirm?
