5G Module on Jetson AGX Orin
I know that this might be the best place to ask this question, but since I’ve already tried everything I knew and opened any online resource I could find I’m also asking here…
I’m trying to setup my 5G module (RM500Q-GL) on my Jetson AGX Orin. I know for a fact that they are compatible, nevertheless I cannot find any way to set it up.
I have downloaded the kernel sources and enabled both cdc-wdm and qmi_wwan mod probes, nevertheless, not even “lsusb -t” can find the 5G module.
On the hardware level, I have also set it up correctly since I was able to also do it on my Jetson Xavier NX.
Could you please let me know if you know anything else I should try?
Thank you beforehand.
