8265NGW WIFI hard blocked
Jetson xavier nx using RTL8822CE wifi is work well. 8265ngw WIFI module can’t work.
dmesg.log (69.1 KB)
Not sure which JetPack SW you’re using.
We have tested it and Intel 8265 card can get detected on our board. Are you sure you are using devkit?
$ lspci
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad1 (rev a1)
0004:01:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1)
0005:01:00.0 Non-Volatile memory controller: Silicon Motion, Inc. Device 2263 (rev 03)
JetPack is R35.3.1.
The development board is developed by myself. I don’t know Which GPIO pin signal is causing this WIFI module to be hard blocked.
I found the problem! fixed it!
