Hey
Data conversion tab is missing after I make few changes:
-I added import pythonosc in facsSolver.py in C:\Users\USER\AppData\Local\ov\pkg\audio2face-2022.2.1\exts\omni.audio2face.exporter\omni\audio2face\exporter\scripts
-Opened A2F and Audio2Face/Open Demo Scene/Regular Core-streaming player
-A2F version 2022.2.1
Can it be that A2F can not find pythonosc module?
Can you please send your latest Audio2Face log file which can be found here: C:\Users\<USERNAME>\.nvidia-omniverse\logs\Kit\Audio2Face
From the log file, it appears there’s something wrong with this line from pythonosc import upd_client
Failed to import python module omni.audio2face.exporter. Error: cannot import name 'upd_client' from 'pythonosc'
Can you make sure pythonosc
is in the PYTHONPATH
I typed
python -c “import pythonosc”
in command line and there wasn’t any error, so I’m assuming that PYTHONPATH for pythonosc is fine.
but when I go to Script Editor in A2F and type
import python
print(pythonosc)
I receive an error:
OSError: [Errno 22] Invalid argument
At:
c:/users/USER/appdata/local/ov/pkg/audio2face-2022.2.1/kit/kernel/py\omni\kit\app_impl_init_.py(137): write
c/users/…/appdata/local/temp/x17ao.0/script_1684395829.py(2):
I SOLVED THE ISSUE!
facssolver.py file I also added some line code adding python osc library.
Before I had:
but importing whole library solved the problem:
import pythonosc
