Audio2Face tab is missing/not coming up. In logs it shows ddl fail load failed
2021-07-10 18:14:38 [68,994ms] [Error] [carb.python] Failed to import python module omni.audio2face.core. Error: DLL load failed: A dynamic link library (DLL) initialization routine failed… Traceback:
File “e:/omniverse/pkg/audio2face-2021.2.5/kit/plugins/bindings-python\omni\ext\impl_internal.py”, line 65, in import_module
return importlib.import_module(name)
File “e:\omniverse\pkg\audio2face-2021.2.5\kit\python\lib\importlib_init_.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1006, in _gcd_import
File “”, line 983, in _find_and_load
File “”, line 967, in _find_and_load_unlocked
File “”, line 677, in _load_unlocked
File “”, line 728, in exec_module
File “”, line 219, in call_with_frames_removed
File "e:\omniverse\pkg\audio2face-2021.2.5\exts\omni.audio2face.core\omni\audio2face\core_init.py", line 1, in
from .scripts.extension import *
File “e:\omniverse\pkg\audio2face-2021.2.5\exts\omni.audio2face.core\omni\audio2face\core\scripts\extension.py”, line 52, in
a2f = _import_a2f()
File “e:\omniverse\pkg\audio2face-2021.2.5\exts\omni.audio2face.core\omni\audio2face\core\scripts\extension.py”, line 48, in import_a2f
a2f_spec.loader.exec_module(a2f)
File “e:\omniverse\pkg\audio2face-2021.2.5\exts\omni.audio2face.core_deps\deps\audio2face-sdk\python/audio2face/init.py”, line 1, in
from . import core
File "e:\omniverse\pkg\audio2face-2021.2.5\exts\omni.audio2face.core_deps\deps\audio2face-sdk\python/audio2face\core_init.py", line 1, in
from ._audio2face import *
ImportError: DLL load failed: A dynamic link library (DLL) initialization routine failed.
2021-07-10 18:14:38 [68,994ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.audio2face.core’ in ‘e:/omniverse/pkg/audio2face-2021.2.5/exts/omni.audio2face.core/.’ failed to load.
At:
e:/omniverse/pkg/audio2face-2021.2.5/kit/plugins/bindings-python\omni\ext\impl_internal.py(169): startup_all_extensions_in_module
e:/omniverse/pkg/audio2face-2021.2.5/kit/plugins/bindings-python\omni\ext\impl_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2):
2021-07-10 18:14:38 [68,994ms] [Error] [omni.ext.plugin] [ext: omni.audio2face.core-0.1.1] Failed to process python module extension in ‘e:/omniverse/pkg/audio2face-2021.2.5/exts/omni.audio2face.core/.’.
logs.txt (13.1 KB)
