hi @kradproductions ,
Thanks for the screen shot. Looks like the audio2face UI is not even loaded.
This currently looks to have the same audio lib isse. On the log:
2021-08-17 03:03:57 [4,579ms] [Error] [carb.python] Failed to import python module omni.audio2face.player from c:\users\evan\appdata\local\ov\pkg\audio2face-2021.2.6\exts\omni.audio2face.player. Error: cannot load library 'c:\users\evan\appdata\local\ov\pkg\audio2face-2021.2.6\exts\omni.audio2face.player_deps\deps\py\_sounddevice_data\portaudio-binaries\libportaudio64bit.dll': error 0xc1. Traceback:
File "c:\users\evan\appdata\local\ov\pkg\audio2face-2021.2.6\exts\omni.audio2face.player_deps\deps\py\sounddevice.py", line 71, in <module>
raise OSError('PortAudio library not found')
OSError: PortAudio library not found
During handling of the above exception, another exception occurred:
File "c:/users/evan/appdata/local/ov/pkg/audio2face-2021.2.6/kit/plugins/bindings-python\omni\ext\impl\_internal.py", line 155, in _custom_importer
return _import_public(folder, module_name)
File "c:/users/evan/appdata/local/ov/pkg/audio2face-2021.2.6/kit/plugins/bindings-python\omni\ext\impl\_internal.py", line 114, in _import_public
module = import_module(module_name)
File "c:/users/evan/appdata/local/ov/pkg/audio2face-2021.2.6/kit/plugins/bindings-python\omni\ext\impl\_internal.py", line 65, in import_module
return importlib.import_module(name)
File "c:\users\evan\appdata\local\ov\pkg\audio2face-2021.2.6\kit\python\lib\importlib\__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "c:\users\evan\appdata\local\ov\pkg\audio2face-2021.2.6\exts\omni.audio2face.player\omni\audio2face\player\__init__.py", line 1, in <module>
from .scripts.extension import *
File "c:\users\evan\appdata\local\ov\pkg\audio2face-2021.2.6\exts\omni.audio2face.player\omni\audio2face\player\scripts\extension.py", line 38, in <module>
a2f_audio = _import_a2f_audio()
File "c:\users\evan\appdata\local\ov\pkg\audio2face-2021.2.6\exts\omni.audio2face.player\omni\audio2face\player\scripts\extension.py", line 34, in _import_a2f_audio
a2f_audio_spec.loader.exec_module(a2f_audio)
File "c:\users\evan\appdata\local\ov\pkg\audio2face-2021.2.6\exts\omni.audio2face.player_deps\deps\audio2face-sdk\python/audio2face/audio/__init__.py", line 2, in <module>
from .audio_player import *
File "c:\users\evan\appdata\local\ov\pkg\audio2face-2021.2.6\exts\omni.audio2face.player_deps\deps\audio2face-sdk\python/audio2face/audio\audio_player.py", line 2, in <module>
import sounddevice
File "c:\users\evan\appdata\local\ov\pkg\audio2face-2021.2.6\exts\omni.audio2face.player_deps\deps\py\sounddevice.py", line 83, in <module>
_lib = _ffi.dlopen(_libname)
OSError: cannot load library 'c:\users\evan\appdata\local\ov\pkg\audio2face-2021.2.6\exts\omni.audio2face.player_deps\deps\py\_sounddevice_data\portaudio-binaries\libportaudio64bit.dll': error 0xc1
2021-08-17 03:03:57 [4,579ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.audio2face.player' in 'c:/users/evan/appdata/local/ov/pkg/audio2face-2021.2.6/exts/omni.audio2face.player/.' failed to load.
At:
c:/users/evan/appdata/local/ov/pkg/audio2face-2021.2.6/kit/plugins/bindings-python\omni\ext\impl\_internal.py(169): startup_all_extensions_in_module
c:/users/evan/appdata/local/ov/pkg/audio2face-2021.2.6/kit/plugins/bindings-python\omni\ext\impl\_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2): <module>
is that libportaudio64bit.dll the one you replaced?
I’ll check with the team if they have any more ideas.
