About activating spi on jetson nano
Hello, @ShaneCCC
Another question for an old post.
Remove the TEGRA_GPIO B an B to try
I didn’t understand this part.
Do you mean to delete TEGRA_GPIO(BB, 0) below?
Are you telling me to delete TEGRA_GPIO(B, 4)?
Thank you.
Remove all of the (B, 4 5 6 7 group from the device tree if you stay in r32.6.x release.
Hello, @ShaneCCC
**If I use R32.7.x, do I need to delete the above?
just from tegra210-porg-pinmux-p3448-0002-b00.dtsi
nvidia,pins = “spi1_mosi_pc0”;
nvidia,function = “spi1”;
nvidia,pin-label = “spi1_dout”;
nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
Can I set it up as above?
Thank you.
No need for r32.7.x due to those context already removed for this release.
Hello, @ShaneCCC
Then in R32.7.x, what kind of work is needed to activate spi?
Even if you set it like the link above
sudo cat /sys/kernel/debug/tegra_pinctrl_reg | If you check grep -i spi, you will see something like this:
sudo cat /sys/kernel/debug/tegra_pinctrl_reg | grep -i spi
[sudo] password for manager:
Bank: 1 Reg: 0x70003050 Val: 0x0000e015 → spi1_mosi_pc0
Bank: 1 Reg: 0x70003054 Val: 0x0000e015 → spi1_miso_pc1
Bank: 1 Reg: 0x70003058 Val: 0x0000e015 → spi1_sck_pc2
Bank: 1 Reg: 0x7000305c Val: 0x0000e015 → spi1_cs0_pc3
Bank: 1 Reg: 0x70003060 Val: 0x0000e015 → spi1_cs1_pc4
Bank: 1 Reg: 0x70003064 Val: 0x00006016 → spi2_mosi_pb4
Bank: 1 Reg: 0x70003068 Val: 0x00006016 → spi2_miso_pb5
Bank: 1 Reg: 0x7000306c Val: 0x00006016 → spi2_sck_pb6
Bank: 1 Reg: 0x70003070 Val: 0x00006016 → spi2_cs0_pb7
Bank: 1 Reg: 0x70003074 Val: 0x00006015 → spi2_cs1_pdd0
Bank: 1 Reg: 0x70003078 Val: 0x0000e015 → spi4_mosi_pc7
Bank: 1 Reg: 0x7000307c Val: 0x0000e015 → spi4_miso_pd0
Bank: 1 Reg: 0x70003080 Val: 0x0000e015 → spi4_sck_pc5
Bank: 1 Reg: 0x70003084 Val: 0x0000e015 → spi4_cs0_pc6
Bank: 1 Reg: 0x70003088 Val: 0x00002015 → qspi_sck_pee0
Bank: 1 Reg: 0x7000308c Val: 0x00002015 → qspi_cs_n_pee1
Bank: 1 Reg: 0x70003090 Val: 0x00002015 → qspi_io0_pee2
Bank: 1 Reg: 0x70003094 Val: 0x00002015 → qspi_io1_pee3
Bank: 1 Reg: 0x70003098 Val: 0x00002015 → qspi_io2_pee4
Bank: 1 Reg: 0x7000309c Val: 0x00002015 → qspi_io3_pee5
Bank: 0 Reg: 0x70000b70 Val: 0x00000001 → drive_qspi_comp_control
Bank: 0 Reg: 0x70000b78 Val: 0x00000001 → drive_qspi_lpbk_control
Bank: 0 Reg: 0x70000a78 Val: 0x00808000 → drive_qspi_comp
Create dtb after kernel build
It was applied with FDT.
Can you also tell me how to make dtb to enable spi through NV_Jetson_Nano_Module_Pinmux_Config_Template.xlsm ?
Thank you.
You just need to run the jetson-io to configure the PINs for SPI.
Hello, @ShaneCCC
I’m using jetson nano emmc module.
Thank you.
You need to modify the device tree like the reference topic you point out.
gst-launch-1.0 rtspsrc location=rtsp://root:root@10.10.237.101:554/cam0_0 ! rtpjpegdepay ! jpegparse ! jpegdec ! videoconvert ! video/x-raw,format=NV12 ! nvvideoconvert ! video/x-raw,format=NV12 ! nveglglessink -e
