I am currently working on the camera hardware design for Jetson TX1.
I know JTX1 has 2 MCLK for 2 cameras but my board has 3 cameras.
I read the Jetson TX1 camera module hardware design guide, which suggests using a clock buffer.
But there is a thread about this
https://devtalk.nvidia.com/default/topic/936727/about-csi-camera-master-clock/?offset=5
where Trumany said “Using one MCLK to supply multi cameras should work.”
So I wonder if I can directly connect an MCLK output from JTX1 to 2 cameras’ MCLK pins without a clock buffer? BTW, those 2 cameras are the same and work at the same time.
And another question, if needed, is there any clock buffer IC recommended? I am new to stuff like this.
Thanks a lot.
