We have buy some NX Module, found the dont have the heat spreader, but the TX2 and Nano has this, and we also found the NX thermal design guide have the heat spreader, so Im little confused for this, NX should have this heat Spreader or not?
No TTP for it as you can see in thermal design guide in DLC.
ok thanks
You can find a heat sink+fan part for NX module.
FYI - we are now stocking thermal spreaders for the NX as well as a leaf-spring kit (if you’ve designed your own spreader and have issues sourcing the mounting hardware).
