About OX08B40 camera sensor is problem
[2025/11/13 10:28:27] # entries-in-buffer/entries-written: 22740/22740 #P:8
[2025/11/13 10:28:27] # _-----=> irqs-off
[2025/11/13 10:28:27] # / _----=> need-resched
[2025/11/13 10:28:27] # | / _—=> hardirq/softirq
[2025/11/13 10:28:27] # || / _–=> preempt-depth
[2025/11/13 10:28:27] # ||| / delay
[2025/11/13 10:28:27] # TASK-PID CPU# |||| TIMESTAMP FUNCTION
[2025/11/13 10:28:27] # | | | |||| | |
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 86.703791: rtcpu_string: tstamp:3888998435 id:0x04010000 str:“VM0 deactivating.”
[2025/11/13 10:28:27] v4l2-ctl-3789 [003] … 98.384001: tegra_channel_open: vi-output, ox08b40 30-0036
[2025/11/13 10:28:27] v4l2-ctl-3789 [003] … 98.409150: tegra_channel_set_power: ox08b40 30-0036 : 0x1
[2025/11/13 10:28:27] v4l2-ctl-3789 [003] … 98.409173: camera_common_s_power: status : 0x1
[2025/11/13 10:28:27] v4l2-ctl-3789 [003] … 98.415230: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
[2025/11/13 10:28:27] v4l2-ctl-3789 [003] … 98.415234: csi_s_power: enable : 0x1
[2025/11/13 10:28:27] v4l2-ctl-3789 [003] … 98.415987: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt c4
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.422591: rtcpu_string: tstamp:4255960938 id:0x04010000 str:“VM0 activating.”
[2025/11/13 10:28:27] v4l2-ctl-3789 [005] … 98.423346: tegra_channel_set_stream: enable : 0x1
[2025/11/13 10:28:27] v4l2-ctl-3789 [005] … 98.440162: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
[2025/11/13 10:28:27] v4l2-ctl-3789 [005] … 98.440165: csi_s_stream: enable : 0x1
[2025/11/13 10:28:27] v4l2-ctl-3789 [005] … 98.440498: tegra_channel_set_stream: ox08b40 30-0036 : 0x1
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.478592: rtcpu_vinotify_event: tstamp:4256618494 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:136195712544 data:0x399d580010000000
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.478593: rtcpu_vinotify_event: tstamp:4256618633 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:136195719008 data:0x0000000031000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.478593: rtcpu_vinotify_event: tstamp:4256618793 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:136195775232 data:0x399d550010000000
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.478593: rtcpu_vinotify_event: tstamp:4256618927 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:136195781824 data:0x0000000031000002
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982968: rtcpu_nvcsi_intr: tstamp:4273168578 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982970: rtcpu_nvcsi_intr: tstamp:4273168578 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982971: rtcpu_nvcsi_intr: tstamp:4273168578 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982971: rtcpu_nvcsi_intr: tstamp:4273168578 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982972: rtcpu_nvcsi_intr: tstamp:4273170899 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982973: rtcpu_nvcsi_intr: tstamp:4273170899 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982974: rtcpu_nvcsi_intr: tstamp:4273175685 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982974: rtcpu_nvcsi_intr: tstamp:4273175685 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982975: rtcpu_nvcsi_intr: tstamp:4273180470 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982975: rtcpu_nvcsi_intr: tstamp:4273180470 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982976: rtcpu_nvcsi_intr: tstamp:4273184845 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982977: rtcpu_nvcsi_intr: tstamp:4273184845 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982977: rtcpu_nvcsi_intr: tstamp:4273188674 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982978: rtcpu_nvcsi_intr: tstamp:4273188674 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982979: rtcpu_nvcsi_intr: tstamp:4273191953 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982979: rtcpu_nvcsi_intr: tstamp:4273191953 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982980: rtcpu_nvcsi_intr: tstamp:4273193459 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982980: rtcpu_nvcsi_intr: tstamp:4273193459 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982981: rtcpu_nvcsi_intr: tstamp:4273198242 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982982: rtcpu_nvcsi_intr: tstamp:4273198242 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982982: rtcpu_nvcsi_intr: tstamp:4273200156 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982983: rtcpu_nvcsi_intr: tstamp:4273200156 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982983: rtcpu_nvcsi_intr: tstamp:4273204395 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982984: rtcpu_nvcsi_intr: tstamp:4273204395 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982984: rtcpu_nvcsi_intr: tstamp:4273206856 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982984: rtcpu_nvcsi_intr: tstamp:4273206856 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982985: rtcpu_nvcsi_intr: tstamp:4273207814 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982985: rtcpu_nvcsi_intr: tstamp:4273207814 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982986: rtcpu_nvcsi_intr: tstamp:4273212599 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982986: rtcpu_nvcsi_intr: tstamp:4273212599 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982987: rtcpu_nvcsi_intr: tstamp:4273214920 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982987: rtcpu_nvcsi_intr: tstamp:4273214920 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982987: rtcpu_nvcsi_intr: tstamp:4273222170 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982988: rtcpu_nvcsi_intr: tstamp:4273222170 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982988: rtcpu_nvcsi_intr: tstamp:4273224492 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982988: rtcpu_nvcsi_intr: tstamp:4273224492 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982989: rtcpu_nvcsi_intr: tstamp:4273227912 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982989: rtcpu_nvcsi_intr: tstamp:4273227912 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982990: rtcpu_nvcsi_intr: tstamp:4273229277 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982990: rtcpu_nvcsi_intr: tstamp:4273229277 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982991: rtcpu_nvcsi_intr: tstamp:4273235020 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982991: rtcpu_nvcsi_intr: tstamp:4273235020 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982991: rtcpu_nvcsi_intr: tstamp:4273238439 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
[2025/11/13 10:28:27] kworker/7:2-157 [007] … 98.982992: rtcpu_nvcsi_intr: tstamp:4273238439 class:CORRECTABLE_ERR type:STREAM
This forum is exclusively for developers who are part of the NVIDIA DRIVE™ AGX SDK Developer Program. To post in the forum, please use an account associated with your corporate or university email address.
This helps us ensure that the forum remains a platform for verified members of the developer program.
If you’re using Jetson platform, please open your issue at Latest Robotics & Edge Computing/Jetson & Embedded Systems topics - NVIDIA Developer Forums
